Is Rest API update method for article is not thread save ?
Hi
I have problem with shopware 5 rest api update method. When I use rest api and i try to update product i got integrity constraint violation error but error only occurs only when i do update in parallel manner.
Integrity constraint violation: 1062 Duplicate entry ‚20874-1349‘ for key 'articleID
When I do update in normal way , in one thread error not occurs. Do you have idea what can cause the error?
Here are similar link issues:
https://forum.shopware.com/discussion/53517/sql-error-bei-produkt-api
https://forum.shopware.com/discussion/15949/rest-api-duplicate-entry-for-primary
It looks like the problem is not with duplicated data. It could be because of the access the same resource inside flush method in the same time. I am not sure how i can fix that ?
