"Invalid access token"
Halloo,
Ich habe meine DEV in einem Unterverzeichnis liegen.
Wie kann ich trotzdem das Update auf 6.7 durchführen ?
Run Update preparations
pre-update-cmd: Symfony\Flex\Flex->configureInstaller
Loading composer repositories with package information
In CurlDownloader.php line 660:
[Composer\Downloader\TransportException (100)]
The „https://packages.shopware.com/packages.json“ file could not be downloa
ded (HTTP/2 400 ):
„Invalid access token“
Das sollte eigentlich dennoch funktionieren. Wie hast du denn das Update deiner Dev-Umgebung initiiert?
Übe den Update Manager und dann kommt die Fehlermeldung.
  The "https://packages.shopware.com/packages.json" file could not be downloa
  ded (HTTP/2 400 ):
Exception trace:
  at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Util/Http/CurlDownloader.php:660
 Composer\Util\Http\CurlDownloader->failResponse() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Util/Http/CurlDownloader.php:460
 Composer\Util\Http\CurlDownloader->tick() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Util/HttpDownloader.php:392
 Composer\Util\HttpDownloader->countActiveJobs() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Util/HttpDownloader.php:363
 Composer\Util\HttpDownloader->wait() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Util/HttpDownloader.php:114
 Composer\Util\HttpDownloader->get() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Repository/ComposerRepository.php:1485
 Composer\Repository\ComposerRepository->fetchFile() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Repository/ComposerRepository.php:1194
 Composer\Repository\ComposerRepository->loadRootServerFile() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Repository/ComposerRepository.php:822
 Composer\Repository\ComposerRepository->hasProviders() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Repository/ComposerRepository.php:483
 Composer\Repository\ComposerRepository->loadPackages() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/DependencyResolver/PoolBuilder.php:435
 Composer\DependencyResolver\PoolBuilder->loadPackagesMarkedForLoading() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/DependencyResolver/PoolBuilder.php:279
 Composer\DependencyResolver\PoolBuilder->buildPool() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Repository/RepositorySet.php:332
 Composer\Repository\RepositorySet->createPool() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Installer.php:501
 Composer\Installer->doUpdate() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Installer.php:298
 Composer\Installer->run() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Command/UpdateCommand.php:281
 Composer\Command\UpdateCommand->execute() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/symfony/console/Command/Command.php:326
 Symfony\Component\Console\Command\Command->run() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:1078
 Symfony\Component\Console\Application->doRunCommand() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:324
 Symfony\Component\Console\Application->doRun() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Console/Application.php:397
 Composer\Console\Application->doRun() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:175
 Symfony\Component\Console\Application->run() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Console/Application.php:137
 Composer\Console\Application->run() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/composer/composer/bin/composer:99
 include() at phar:///www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php/vendor/bin/composer:119
 require() at /www/htdocs/w01f0884/baby-lala.wien/staging/public/shopware-installer.phar.php:37
update [--with WITH] [--prefer-source] [--prefer-dist] [--prefer-install PREFER-INSTALL] [--dry-run] [--dev] [--no-dev] [--lock] [--no-install] [--no-audit] [--audit-format AUDIT-FORMAT] [--no-autoloader] [--no-suggest] [--no-progress] [-w|--with-dependencies] [-W|--with-all-dependencies] [-v|vv|vvv|--verbose] [-o|--optimize-autoloader] [-a|--classmap-authoritative] [--apcu-autoloader] [--apcu-autoloader-prefix APCU-AUTOLOADER-PREFIX] [--ignore-platform-req IGNORE-PLATFORM-REQ] [--ignore-platform-reqs] [--prefer-stable] [--prefer-lowest] [-m|--minimal-changes] [--patch-only] [-i|--interactive] [--root-reqs] [--bump-after-update [BUMP-AFTER-UPDATE]] [--] [...]
