Tomasz
                    13. Juli 2018 um 07:34
                  1
              Hello, I’m trying to change my Articles after Infinite Scrolling work. I need to find event that will handle it. I tried
 Enlight\_Controller\_Action\_PostDispatchSecure\_Widgets\_Listing
 Shopware\_Modules\_Articles\_sGetArticlesByCategory\_FilterResult
Enlight_Controller_Action_Widgets_Listing_listingCount
But non of them work.
              Can you provide your code?
Infinity scrolling invoked by url:
/widgets/Listing/ajaxListing?p=[pageNumber]&c=[categoryId]
So both of events subscribes should works for you:
Enlight_Controller_Action_PostDispatchSecure_Widgets_Listing
Shopware_Modules_Articles_sGetArticlesByCategory_FilterResult
Is it possible that you haven’t reinstalled plugin after add these subscribers?
Try to assign some variable and check is it available on template or just die(); in event hendler:
_/\*\*_ _\*_ _@param_ _\Enlight\_Controller\_ActionEventArgs $args_ _\*_ _@return_ _bool_ _\*/_ **public function** postDispatchFrontendWidgets(\Enlight\_Controller\_ActionEventArgs $args) { $request = $args-\>getSubject()-\>Request(); $action = $args-\>getSubject(); $response = $action-\>Response(); $view = $action-\>View(); $assignData = $view-\>getAssign( **'articles'** ); $sArticles = $view-\>getAssign( **'sArticles'** ); **if** (!$request-\>isDispatched() || $response-\>isException() || !$view-\>hasTemplate() || ( **empty** ($assignData) && **empty** ($sArticles) ) ) { **return false** ; } $view-\>assign( **'myVariable'** , **'myValue'** ); }
                Tomasz
                    13. Juli 2018 um 17:15
                  3
              It used to work but they changed controller from widgets/listing/ajaxListing to widgets/listing/listingCount. You can’t use $view->getAssign(‘sArticles’) because controller’s response is json.
 $this-\>Front()-\>Plugins()-\>ViewRenderer()-\>setNoRender(); $this-\>Response()-\>setBody(json\_encode($body)); $this-\>Response()-\>setHeader('Content-type', 'application/json', true);
              Then you should replace data in body?
_/\*\*_ _\*_ _@param_ _\Enlight\_Controller\_ActionEventArgs $args_ _\*_ _@return_ _bool_ _\*/_ **public function** postDispatchFrontendWidgets(\Enlight\_Controller\_ActionEventArgs $args) { $action = $args-\>getSubject(); $response = $action-\>Response(); $body = _json\_decode_($response-\>getBody(), **true** ); **if** (! **empty** ($body)){ $body[**'totalCount'**] = 0; } $response-\>setBody(_json\_encode_($body)); }
