Indexing keeps stuck
My 6.4 install keeps indexing products and categories.
This is allready running for a week, without any progress
If i check the logs i see the following error
Reached max depth, aborting from Treeupdater.php
Any idea where this goes wrong? And ideas how to debug this?
thanks in advance!
Hey @JustinB,
using the queue when generating/refreshing the index could help you. The following command should do the trick.
php bin/console dal:refresh:index --use-queue
Kind regards,
Patrick
I had the same Problem.
In 6.4 was an error with custom fields and the index generation.
With the update to 6.4.4.0 this problem was solved.
See also:
