wahrscheinlich handelt es sich nur um eine Kleinigkeit:
generell funktioniert mein SSL überall nur auf der Startseite nicht. Benötigt meine htacess evt eine kleine Änderung?
Ich hoffe es kann mir jemand helfen. (Shopware 5.1.3)
RewriteEngine on
RewriteBase /
RewriteEngine On
# Https config for the backend
#RewriteCond %{HTTPS} !=on
#RewriteRule backend/(.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
RewriteRule backend/media/(.*) media/$1 [NC,L]
RewriteCond %{REQUEST_URI} !(\/(engine|files|templates|themes|web)\/)
RewriteCond %{REQUEST_URI} !(\/media\/(archive|banner|image|music|pdf|unknown|video)\/)
RewriteRule ^(.*)$ shopware.php [PT,L,QSA]
# Fix missing authorization-header on fast_cgi installations
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
# Block access to VCS directories
RedirectMatch 404 /\\.(svn|git|hg|bzr|cvs)(/|$)
# Restrict access to root folder files
RedirectMatch 404 /(composer\.(json|lock)|README\.md|UPGRADE\.md)$
# Staging environment
#SetEnvIf Host "staging.test.shopware.in" SHOPWARE_ENV=staging
# Development environment
#SetEnvIf Host "dev.shopware.in" SHOPWARE_ENV=dev
#SetEnv SHOPWARE_ENV dev
DirectoryIndex index.html
DirectoryIndex index.php
DirectoryIndex shopware.php
# Disables download of configuration
# Deny all requests from Apache 2.4+.
Require all denied
# Deny all requests from Apache 2.0-2.2.
Deny from all
# Enable gzip compression
AddOutputFilterByType DEFLATE text/html text/xml text/plain text/css text/javascript application/javascript application/json
ExpiresActive on
ExpiresDefault "access plus 1 month"
Header append Cache-Control "public"
Header unset ETag
FileETag None
# Match generated files like:
# 1429684458_t22_s1.css
# 1429684458_t22_s1.js
Header set Cache-Control "max-age=31536000, public"
ExpiresActive on
ExpiresDefault "access plus 1 year"
# Disables auto directory index
Options -Indexes
Options -MultiViews
php_value memory_limit 256M
php_value max_execution_time 120
# php_value upload_max_filesize 20M
php_flag phar.readonly off
php_flag magic_quotes_gpc off
php_flag session.auto_start off
php_flag suhosin.session.cryptua off
php_flag zend.ze1_compatibility_mode off
# AddType x-mapp-php5 .php
# AddHandler x-mapp-php5 .php
Header append X-Frame-Options SAMEORIGIN
mfg
thevaethi
