Hi
I am using the ProductEvents:: PRODUCT_LOADED_EVENT subscriber. I want to redirect to the home page in certain conditions.
public static function getSubscribedEvents(): array
return [
ProductEvents::PRODUCT_LOADED_EVENT => ‘onProductLoaded’
public function onProductLoaded(EntityLoadedEvent $event)
//Some conditions
if()
$pageVisible = false;
if(!$pageVisible)
// redirect to homepage
return $this->redirectToRoute(‘frontend.home.page’);
return;
How to redirect to the home page from a subscriber file?
If you want to redirect in Shopware way you have to use an event like “RequestEvent”.
use Symfony\Component\HttpFoundation\RedirectResponse;
use Symfony\Component\HttpKernel\Event\RequestEvent;
use Symfony\Component\HttpKernel\KernelEvents;
return [
KernelEvents::REQUEST => 'onCmsPageLoaded'
public function onCmsPageLoaded(RequestEvent $event)
$request = $event->getRequest();
$attributes = $request->attributes;
$route = $attributes->get('_route');
if($route == 'frontend.cms.page')
$response = new RedirectResponse($this->router->generate('frontend.home.page'), 301);
$event->setResponse($response);
return;
Hi @abinjohnedamana,
how do you access event specific data in your case?
I need information about a logged in customer from the context but with the Kernel Request Event I don’t have access to the context anymore.
Vice versa I am not able to redirect if I use a non-kernel event
Hi @lucamario
You can try the following
KernelEvents::RESPONSE => 'onProductDetailPageLoaded',
public function onProductDetailPageLoaded(ResponseEvent $event): void
if ($event->getResponse() instanceof StorefrontResponse) {
$this->checkCadcamOrScannerProduct($event);
return;
public function checkCadcamOrScannerProduct($event)
$route = $event->getRequest()->attributes->get('_route');
/** @var StorefrontResponse */
$response = $event->getResponse();
/** @var SalesChannelContext */
$salesChannelContext = $response->getContext();
$customer = $salesChannelContext->getCustomer();
if(!$customer)
return true;
Works perfect, thank you @abinjohnedamana !
