How to hide grid action buttons(Edit, Delete) from “sw-entity-listing” listing in shopware 6?
You could extend the base component and empty the blocks for those actions
Thank you for your replay
I have found the following lines of code in /var/www/html/shopware6/development/platform/src/Administration/Resources/app/administration/src/app/component/data-grid/sw-data-grid.html.twig
{% block sw_data_grid_body_cell_actions %}
{% block sw_data_grid_slot_actions %}{% endblock %}{% endblock %}
I have tried the following
{% endblock %}Not working(Showing Edit, Delete options)
ok
Edit, Delete options hide but still showing the button
How to hide the button and the edit, delete options from admin side listing?
Like so
Component.extend('my-listing', 'sw-entity-listing', {
template: '{% block sw_data_grid_body_cell_actions %}{% endblock %}'
And use
use :showActions=“false”
eg: v-if=“customerSearchKeywords”
:items=“customerSearchKeywords”
:repository=“repository”
:showSelection=“false”
:columns=“columns”
:sortBy=“sortBy”
:sortDirection=“sortDirection”
:isLoading=“isLoading”
@column-sort=“onSortColumn”>
