I import products essentially by calling productrepository.upsert(['name'=>...]);
What is the established best practice to append product pictures, so that they get saved to disk and all the media_* tables get populated?
Thanks!
Thanks!
That is awesome, thank you so much.
My rather ugly approach was to first create the entity via the product repository with
'id' => <productid>,
'productNumber' =>...,
'media' => [
'id' => ...,
'position' => 0,
'media' => [
'id' => ...,
'fileName' => ...,
'fileSize' => ...,
'mediaFolderId' => $this->getDefaultProductMediaFolderId(),
then load that entity, work out the directory the picture is expected to be in, and save the image there.
It kinda worked, but screwed the thumbnail generation.
