Hi.
I want to add a new filter in storefront just like the manufacturer, color, length etc. How do I do that?
You have to create a property in the backend, associate it with a product and shopware will do the rest.
Did you assign this filter to any product? Only filters that are in use are displayed in the storefront.
how to assign a product to it?
Open a product, go to section properties (I guess it is called so) and select a property
Ok found it. I just had to search in the values for it.
And the solution works. Thank you
