Im developing a plugin integrating an external API.
As a response to the API calls i want to print some images into DOM.
My question is:
How can I serve custom images with my plugin into storefront?
I have extended a file and inside of a block im trying to use:
That generates the URL “/public/test.jpg”
Which directory should i place my image on and how to call it properly in Twig template?
Thanks.
