Plugin directory :
$PROJECTROOT
- src
-- Controller
-- Resources
-- app
-- administration
-- build
--- webpack.config.js
-- img
-- js
-- src
--- folder-name
---- page
----- folder-name
------- index.js
------- file.html.twig
------- filename.scss
---- index.js
--- main.js
Webpack.config.js
const { join, resolve } = require('path');
module.exports = () => {
return {
output: {
publicPath:join(__dirname, '..', 'img')
resolve: {
alias: {
'@slugify': resolve(
join(__dirname, '..', 'node_modules', 'slugify')
index.js
import { Component, Mixin } from 'src/core/shopware';
import template from './file.html.twig';
Component.register('component-name', {
template,
data() {
return {
image:require("./shopwareimage.jpg")
file.html.twig
{% block name %}
<sw-page class="oxy-hubspot-auth">
<template>
<img v-bind:src={{image}}>
</template>
</sw-page>
{% endblock %}
I want to display image that is in the img or folder-name
i tried to use require method but didn’t work
i have tried to set public path publicPath to webpack but it also didn’t work
How can i display image which is with in same directory of twig file ?
