Get full url to a product and to a product image
I’m creating a Shopware plugin to create a xml feed.
In this xml feed I want to put all articles, with for every article an url to the article + an url to the image.
I have found an url to both, but both gets redirected to another url.
I want to find the url Shopware is redirecting to.
I’m currently using the following code to do it.
But making a curl call to get the url being redirected to is taking a lot of time, and Shopware knows what the correct url is.
So how can I directly access the url Shopware redirects to?
(article param is an Article/Article model)
	 * Build the url to an article
	 * @return string Url to article
	public function getUrlForArticle($article)
		$articleId = $article->getId();
		$host = Shopware()->Config()->get("host");
		$db = Shopware()->Db();
		$sql = "SELECT path FROM s_core_rewrite_urls WHERE org_path = :org_path";
		$params = [":org_path" => "sViewport=detail&sArticle={$articleId}"];
		$query = $db->executeQuery($sql, $params);
		$row = $query->fetch();
		return isset($row['path']) ? "http://{$host}/{$row['path']}" : "";
	public function getImageurlForArticle($article)
		// engine/Shopware/Controllers/Frontend/Detail.php on line 99 (sGetArticleById)
		// engine/Shopware/Components/Compatibility/LegacyStructConverter.php on line 375 (convertMediaStruct)
		$image = $article->getImages()->first();
		if( $image )
			$media = $image->getMedia();
			$path = $media->getPath();
			// dont follow urls, takes a looooong time
			// return $this->getUrlRedirectedTo("http://{$host}/{$path}");
			return "http://{$host}/{$path}";
        return "";
	 * Get url redirected to for an url
	 * @param string $url Url to follow redirects
	 * @return string Url redirected to
	public function getUrlRedirectedTo($url)
		// http://stackoverflow.com/a/21032909/2492536
	    $ch = curl_init();
	    curl_setopt($ch, CURLOPT_URL, $url); // set url
	    curl_setopt($ch, CURLOPT_HEADER, true); // get header
	    curl_setopt($ch, CURLOPT_NOBODY, true); // do not include response body
	    curl_setopt($ch, CURLOPT_RETURNTRANSFER, true); // do not show in browser the response
	    curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true); // follow any redirects
	    curl_exec($ch);
	    $newUrl = curl_getinfo($ch, CURLINFO_EFFECTIVE_URL); //extract the url from the header response
	    curl_close($ch);
	    return $newUrl;
