Hallo Community, ich habe mal wieder eine Frage. Nachdem ich heute einen Shop aktualisiert habe (von 5.2.22 auf 5.2.24) lädt der Warenkorb Layer.
In den Logs steht folgende Fehlermeldung:
Doctrine\ORM\EntityNotFoundException: Entity of type ‚Shopware\Models\Article\Unit‘ for IDs id(0) was not found in /vendor/doctrine/orm/lib/Doctrine/ORM/EntityNotFoundException.php:47 Stack trace:
#0 /vendor/doctrine/orm/lib/Doctrine/ORM/Proxy/ProxyFactory.php(194): Doctrine\ORM\EntityNotFoundException::fromClassNameAndIdentifier(‚Shopware\Models…‘, Array)
#1 /usr/www/users/tsikgi/var/cache/production_201705171506/doctrine/proxies/__CG__ShopwareModelsArticleUnit.php(230): Doctrine\ORM\Proxy\ProxyFactory->Doctrine\ORM\Proxy{closure}(Object(Shopware\Proxies__CG__\Shopware\Models\Article\Unit), ‚getName‘, Array)
#2 /usr/www/users/tsikgi/var/cache/production_201705171506/doctrine/proxies/__CG__ShopwareModelsArticleUnit.php(230): Closure->__invoke(Object(Shopware\Proxies__CG__\Shopware\Models\Article\Unit), ‚getName‘, Array)
#3 /engine/Shopware/Plugins/Community/Frontend/MoveCheckoutBasePrice/Subscriber/CheckoutSubscriber.php(91): Shopware\Proxies__CG__\Shopware\Models\Article\Unit->getName()
#4 /engine/Shopware/Plugins/Community/Frontend/MoveCheckoutBasePrice/Subscriber/CheckoutSubscriber.php(57): ShopwarePlugins\MoveCheckoutBasePrice\Subscriber\CheckoutSubscriber->addBasePrice(Object(Enlight_View_Default), Array)
#5 /engine/Library/Enlight/Event/Handler/Default.php(91): ShopwarePlugins\MoveCheckoutBasePrice\Subscriber\CheckoutSubscriber->onPostDispatchCheckout(Object(Enlight_Controller_ActionEventArgs))
#6 /engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#7 /engine/Library/Enlight/Controller/Action.php(191): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs))
#8 /engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚ajaxCartAction‘)
#9 /engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#10 /engine/Shopware/Kernel.php(182): Enlight_Controller_Front->dispatch()
#11 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Enlight_Controller_Request_RequestHttp), 1, true)
#12 /engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#13 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#14 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#15 /engine/Shopware/Components/HttpCache/AppCache.php(187): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#16 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#17 /engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#18 /usr/www/users/tsikgi/shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#19 {main}
Hat jemand das gleiche Prob oder kann mir kurz auf die Sprünge helfen, bitte?
Thema hat sich erledigt, es lag leider an einem Plugin, das eigentlich als für 5.2.24 „tauglich“ markiert ist.
