Fehlermeldung Backend
Hallo Ich habe Shopware 5.0.2, wenn man im Backend die Grundeinstellungen aufruft kommt folgemde Fehlermeldung. Shopware.apps.Config.view.base.Form
Unable to load template snippet ‚backend/config/view/base/form.js‘ in Smarty/sysplugins/smarty_internal_templatebase.php on line 127
Stack trace:
#0 Enlight/View/Default.php(274): Smarty\_Internal\_TemplateBase-\>fetch() #1 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default)) #2 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default)) #3 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render() #4 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs)) #5 Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs)) #6 Enlight/Event/EventManager.php(211): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #7 Enlight/Controller/Action.php(202): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #8 Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('loadAction') #9 Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #10 Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #11 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #15 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #16 {main}
Kann jemand sagen was die Ursache dafür ist. Danke Reiner
Hi, er kann die Datei “backend/config/view/base/form.js” nicht finden, die sollte unter ./themes/Backend/ExtJs/backend/config/view/base/form.js liegen. Wenn die nicht da ist, ist vermutlich was beim Upload fehlgeschlagen, ansonsten einmal den Cache komplett leeren und nochmal versuchen. Besten Gruß, Daniel
Danke Daniel Kann man die nachträglich installieren ?
