soeben erhielt ich nachfolgende Fehlermeldung, die ich leide rnicht verstehe. Kann mir bitte jemand den Hintergrund/Ursache erklären ? Danke ,
Bernd
Message:
Shopware\Components\CSRFTokenValidationException: The provided CSRF-Token is invalid. If you're sure that the request to path "/backend/SwagUpdate/requirements?\_dc=1472807509399&%3bpage=1&%3bstart=0&%3blimit=999" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. in /html/shopware/engine/Shopware/Components/CSRFTokenValidator.php:118 Stack trace: #0 /html/shopware/engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator-\>checkBackendTokenValidation(Object(Enlight\_Controller\_ActionEventArgs)) #1 /html/shopware/engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #2 /html/shopware/engine/Library/Enlight/Controller/Action.php(141): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #3 /html/shopware/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('requirementsAct...') #4 /html/shopware/engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #5 /html/shopware/engine/Shopware/Kernel.php(179): Enlight\_Controller\_Front-\>dispatch() #6 /html/shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-\>handle(Object(Enlight\_Controller\_Request\_RequestHttp), 1, true) #7 /html/shopware/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /html/shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /html/shopware/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #10 /html/shopware/shopware.php(117): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #11 {main}
Time:
2017-02-13T09:00:26.345995+0100
Channel:
core
request:
{ "uri": "/backend/SwagUpdate/requirements?\_dc=1472807509399&%3bpage=1&%3bstart=0&%3blimit=999", "method": "GET", "query": { "\_dc": "1472807509399", "amp;page": "1", "amp;start": "0", "amp;limit": "999", "module": "backend", "controller": "SwagUpdate", "action": "requirements" }, "post": [] }
shop:
No shop data available
session:
No session data available
Schließe mich da an. Bekomme ebenso diese bzw. ähnliche Fehlermeldung.
Shopware\Components\CSRFTokenValidationException: The provided X-CSRF-Token for path "/checkout/deleteArticle/sDelete/608/sTargetAction/cart" is invalid. Please go back, reload the page and try again. in /engine/Shopware/Components/CSRFTokenValidator.php:158 Stack trace:
#0 /engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator->checkFrontendTokenValidation(Object(Enlight_Controller_ActionEventArgs))
#1 /engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#2 /engine/Library/Enlight/Controller/Action.php(141): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#3 /engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('deleteArticleAc...')
#4 /engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#5 /engine/Shopware/Kernel.php(180): Enlight_Controller_Front->dispatch()
#6 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Enlight_Controller_Request_RequestHttp), 1, true)
#7 /engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#8 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(275): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /engine/Shopware/Components/HttpCache/AppCache.php(133): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(206): Shopware\Components\HttpCache\AppCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#13 /var/www/vhosts/.../.../shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#14 {main}
hamaca
February 14, 2017, 9:06pm
#3
Wir auch
Shopware\Components\CSRFTokenValidationException: The provided CSRF-Token is invalid. If you're sure that the request to path "/backend/Login?file=app&no-cache=1485326165" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. in /engine/Shopware/Components/CSRFTokenValidator.php:118 Stack trace:
#0 /engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator->checkBackendTokenValidation(Object(Enlight_Controller_ActionEventArgs))
#3 /engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('indexAction')
#5 /engine/Shopware/Kernel.php(179): Enlight_Controller_Front->dispatch()
#9 /engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /is/htdocs/wp1061229_47VO1MQRUV/www/laab/shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#11 {main}
seitdem ich gestern morgen das shopware google-plugin deaktiviert habe, bekam ich keine fehlermeldung mehr…ich habe in einem anderen beitrag gelesen das dieses die ursache sein könnte…mal abwarten ob dies bei mir die lösung ist
