Butz86
29. Januar 2018 um 16:15
1
habe soeben das Update auf 5.3.7 gemacht - alles erfolgreich. Aktuell habe ich jetzt das Problem das es mir beim Klick auf einige Kategorien der „Upps“-Fehler kommt mit folgendem Text:
Facet SwagLiveShopping\Bundle\SearchBundle\Facet\LiveShoppingFacet not supported in engine/Shopware/Bundle/SearchBundleDBAL/ProductNumberSearch.php on line 234
Stack trace:
#0 engine/Shopware/Bundle/SearchBundleDBAL/ProductNumberSearch.php(170): Shopware\Bundle\SearchBundleDBAL\ProductNumberSearch->getFacetHandler(Object(SwagLiveShopping\Bundle\SearchBundle\Facet\LiveShoppingFacet))
#1 engine/Shopware/Bundle/SearchBundleDBAL/ProductNumberSearch.php(101): Shopware\Bundle\SearchBundleDBAL\ProductNumberSearch->createFacets(Object(Shopware\Bundle\SearchBundle\Criteria), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#2 engine/Shopware/Bundle/SearchBundle/ProductSearch.php(65): Shopware\Bundle\SearchBundleDBAL\ProductNumberSearch->search(Object(Shopware\Bundle\SearchBundle\Criteria), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#3 custom/plugins/SwagFuzzy/Bundle/SearchBundle/FuzzyProductSearch.php(54): Shopware\Bundle\SearchBundle\ProductSearch->search(Object(Shopware\Bundle\SearchBundle\Criteria), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#4 engine/Shopware/Core/sArticles.php(2385): SwagFuzzy\Bundle\SearchBundle\FuzzyProductSearch->search(Object(Shopware\Bundle\SearchBundle\Criteria), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#5 engine/Shopware/Core/sArticles.php(456): sArticles->getListing(‚58‘, Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext), Object(Enlight_Controller_Request_RequestHttp), Object(Shopware\Bundle\SearchBundle\Criteria))
#6 engine/Shopware/Controllers/Frontend/Listing.php(520): sArticles->sGetArticlesByCategory(‚58‘, Object(Shopware\Bundle\SearchBundle\Criteria))
#7 engine/Shopware/Controllers/Frontend/Listing.php(83): Shopware_Controllers_Frontend_Listing->loadCategoryListing(‚58‘, Array)
#8 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Frontend_Listing->indexAction()
#9 engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight_Controller_Action->dispatch(‚indexAction‘)
#10 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#11 engine/Shopware/Kernel.php(191): Enlight_Controller_Front->dispatch()
#12 vendor/symfony/http-kernel/HttpCache/HttpCache.php(484): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#13 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#14 vendor/symfony/http-kernel/HttpCache/HttpCache.php(441): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#15 vendor/symfony/http-kernel/HttpCache/HttpCache.php(337): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#16 engine/Shopware/Components/HttpCache/AppCache.php(189): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#17 vendor/symfony/http-kernel/HttpCache/HttpCache.php(203): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#18 engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#19 shopware.php(118): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#20 {main}
An was könnte das liegen? Ich habe schon einige Plugins zum test deaktiviert - ohne erfolg.
Shop: www.ax-men.de
Von welcher Version hast du das Update gemacht?
Sind die Plugin vorher und nachher entsprechend uptodate gehalten worden? Also stehen im Plugin-Manager keine Updates mehr aus?
Butz86
30. Januar 2018 um 07:42
3
Habe von 5.3.6 geupdatet, die Plugins waren alle von den Herstellern freigegeben und natürlich vorher geupdatet.
Butz86
30. Januar 2018 um 14:06
4
Habe jetzt das Shopware Bonus Plugin gelöscht - siehe da, es funktioniert
Exception: Facet SwagLiveShopping\Bundle\SearchBundle\Facet\LiveShoppingFacet not supported in /engine/Shopware/Bundle/SearchBundleDBAL/ProductNumberSearch.php:234 Stack trace:
#0 /engine/Shopware/Bundle/SearchBundleDBAL/ProductNumberSearch.php(170): Shopware\Bundle\SearchBundleDBAL\ProductNumberSearch->getFacetHandler(Object(SwagLiveShopping\Bundle\SearchBundle\Facet\LiveShoppingFacet))
#1 /engine/Shopware/Bundle/SearchBundleDBAL/ProductNumberSearch.php(101): Shopware\Bundle\SearchBundleDBAL\ProductNumberSearch->createFacets(Object(Shopware\Bundle\SearchBundle\Criteria), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#2 /engine/Shopware/Bundle/SearchBundle/ProductSearch.php(65): Shopware\Bundle\SearchBundleDBAL\ProductNumberSearch->search(Object(Shopware\Bundle\SearchBundle\Criteria), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#3 /engine/Shopware/Plugins/Community/Backend/SwagFuzzy/Bundle/SearchBundle/FuzzyProductSearch.php(55): Shopware\Bundle\SearchBundle\ProductSearch->search(Object(Shopware\Bundle\SearchBundle\Criteria), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#4 /engine/Shopware/Core/sArticles.php(2384): ShopwarePlugins\SwagFuzzy\Bundle\SearchBundle\FuzzyProductSearch->search(Object(Shopware\Bundle\SearchBundle\Criteria), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#5 /engine/Shopware/Core/sArticles.php(456): sArticles->getListing('2388', Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext), Object(Enlight_Controller_Request_RequestHttp), Object(Shopware\Bundle\SearchBundle\Criteria))
#6 /engine/Shopware/Controllers/Frontend/Listing.php(520): sArticles->sGetArticlesByCategory('2388', Object(Shopware\Bundle\SearchBundle\Criteria))
#7 /engine/Shopware/Controllers/Frontend/Listing.php(83): Shopware_Controllers_Frontend_Listing->loadCategoryListing('2388', Array)
#8 /engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Frontend_Listing->indexAction()
#9 /engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight_Controller_Action->dispatch('indexAction')
#10 /engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#11 /engine/Shopware/Kernel.php(191): Enlight_Controller_Front->dispatch()
#12 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(484): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#13 /engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#14 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(441): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#15 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(337): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#16 /engine/Shopware/Components/HttpCache/AppCache.php(189): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#17 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(203): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#18 /engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#19 /var/XXX/htdocs/shopware.php(118): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#20 {main}
Ähnliches Problem hier:
