wie beschreiben geht bei mir gar nichts mehr nach einem Update auf Shopware 5.7.16 und der Umstellung auf PHP 8.0.
Im Folgenden die Fehlermeldung. Hat jemand einen Tipp?
Fatal error: Uncaught TypeError: method_exists(): Argument #1 ($object_or_class) must be of type object|string, null given in /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/engine/Library/Enlight/Event/Handler/Plugin.php:148 Stack trace:
#0 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/engine/Library/Enlight/Event/Handler/Plugin.php(148): method_exists(NULL, 'onStartDispatch')
#1 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/engine/Library/Enlight/Event/EventManager.php(207): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_EventArgs))
#2 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/engine/Library/Enlight/Controller/Front.php(132): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_EventArgs))
#3 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/engine/Shopware/Kernel.php(197): Enlight_Controller_Front->dispatch()
#4 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(85): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#5 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/vendor/symfony/http-kernel/HttpCache/HttpCache.php(479): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#6 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#7 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/vendor/symfony/http-kernel/HttpCache/HttpCache.php(452): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#8 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/vendor/symfony/http-kernel/HttpCache/HttpCache.php(346): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/engine/Shopware/Components/HttpCache/AppCache.php(192): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/vendor/symfony/http-kernel/HttpCache/HttpCache.php(224): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/engine/Shopware/Components/HttpCache/AppCache.php(117): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#13 {main} thrown in /is/htdocs/wp12083679_Z5FRN37QK1/www/goekeler_com/engine/Library/Enlight/Event/Handler/Plugin.php on line 148
