Fehler in Shop seit kurzem
Liebe Community
Ich erhalte seit ein paar tagen folgenden fehler in meinem Shop.
ERROR
Message:
 Enlight\_Controller\_Exception: Action "Widgets\_Index\_indexAction" not found failure for request url [https://www.agritec.at/out/flow/src/js/widgets/oxequalizer.min.js?1507729255](https://www.agritec.at/out/flow/src/js/widgets/oxequalizer.min.js?1507729255) in /var/www/vhosts/agritec.at/httpdocs/engine/Library/Enlight/Controller/Action.php:124
 Stack trace:
 #0 /var/www/vhosts/agritec.at/httpdocs/engine/Library/Enlight/Controller/Action.php(192): Enlight\_Controller\_Action-\>\_\_call('indexAction', Array)
 #1 /var/www/vhosts/agritec.at/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight\_Controller\_Action-\>dispatch('indexAction')
 #2 /var/www/vhosts/agritec.at/httpdocs/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #3 /var/www/vhosts/agritec.at/httpdocs/engine/Shopware/Kernel.php(188): Enlight\_Controller\_Front-\>dispatch()
 #4 /var/www/vhosts/agritec.at/httpdocs/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #5 /var/www/vhosts/agritec.at/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(453): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #6 /var/www/vhosts/agritec.at/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #7 /var/www/vhosts/agritec.at/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(426): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #8 /var/www/vhosts/agritec.at/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(317): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true)
 #9 /var/www/vhosts/agritec.at/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(188): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true)
 #10 /var/www/vhosts/agritec.at/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true)
 #11 /var/www/vhosts/agritec.at/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #12 /var/www/vhosts/agritec.at/httpdocs/shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #13 {main}
Time:
 2020-05-01T07:44:27.987993+0200
Channel:
 core
request:
     "uri": "/out/flow/src/js/widgets/oxequalizer.min.js?1507729255",
     "method": "GET",
     "query": {
         "1507729255": "",
         "module": "widgets",
         "controller": "out",
         "action": "flow",
         "src": "js",
         "oxequalizer.min.js": "",
         "0": ""
     "post": []
session:
 No session data available
shopId:
 1
der fehler kommt nicht periodisch sondern ganz willkührlich.
dann wieder alle 2 stunden. kann mit ev. jemand die lösung des problem geben.
danke
