Fehler im Plugin Manager
Hallo, beim Aufruf des Plugin Managers erhalten wir folgende Fehlermeldung: [code]
Could not convert database value "s:21:“https://www.ge…” to Doctrine Type object in vendor/doctrine/dbal/lib/Doctrine/DBAL/Types/ConversionException.php on line 46
Stack trace:
#0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Types/ObjectType.php(59): Doctrine\DBAL\Types\ConversionException::conversionFailed('s:21:"https://w...', 'object') #1 vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/AbstractHydrator.php(330): Doctrine\DBAL\Types\ObjectType-\>convertToPHPValue('s:21:"https://w...', Object(Doctrine\DBAL\Platforms\MySqlPlatform)) #2 vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/ObjectHydrator.php(365): Doctrine\ORM\Internal\Hydration\AbstractHydrator-\>gatherRowData(Array, Array, Array, Array) #3 vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/ObjectHydrator.php(179): Doctrine\ORM\Internal\Hydration\ObjectHydrator-\>hydrateRowData(Array, Array, Array) #4 vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/AbstractHydrator.php(140): Doctrine\ORM\Internal\Hydration\ObjectHydrator-\>hydrateAllData() #5 Doctrine/ORM/Persisters/BasicEntityPersister.php(1017): Doctrine\ORM\Internal\Hydration\AbstractHydrator-\>hydrateAll(Object(PDOStatement), Object(Doctrine\ORM\Query\ResultSetMapping), Array) #6 Doctrine/ORM/Persisters/BasicEntityPersister.php(1757): Doctrine\ORM\Persisters\BasicEntityPersister-\>loadCollectionFromStatement(Array, Object(PDOStatement), Object(Doctrine\ORM\PersistentCollection)) #7 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(2792): Doctrine\ORM\Persisters\BasicEntityPersister-\>loadOneToManyCollection(Array, Object(Shopware\Models\Config\Element), Object(Doctrine\ORM\PersistentCollection)) #8 vendor/doctrine/orm/lib/Doctrine/ORM/PersistentCollection.php(236): Doctrine\ORM\UnitOfWork-\>loadCollection(Object(Doctrine\ORM\PersistentCollection)) #9 vendor/doctrine/orm/lib/Doctrine/ORM/PersistentCollection.php(612): Doctrine\ORM\PersistentCollection-\>initialize() #10 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(2263): Doctrine\ORM\PersistentCollection-\>getIterator() #11 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(1688): Doctrine\ORM\UnitOfWork-\>cascadeRemove(Object(Shopware\Models\Config\Element), Array) #12 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(2278): Doctrine\ORM\UnitOfWork-\>doRemove(Object(Shopware\Models\Config\Element), Array) #13 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(1688): Doctrine\ORM\UnitOfWork-\>cascadeRemove(Object(Shopware\Models\Config\Form), Array) #14 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(2278): Doctrine\ORM\UnitOfWork-\>doRemove(Object(Shopware\Models\Config\Form), Array) #15 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(1688): Doctrine\ORM\UnitOfWork-\>cascadeRemove(Object(Shopware\Models\Plugin\Plugin), Array) #16 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(1659): Doctrine\ORM\UnitOfWork-\>doRemove(Object(Shopware\Models\Plugin\Plugin), Array) #17 vendor/doctrine/orm/lib/Doctrine/ORM/EntityManager.php(647): Doctrine\ORM\UnitOfWork-\>remove(Object(Shopware\Models\Plugin\Plugin)) #18 Shopware/Bundle/PluginInstallerBundle/Service/InstallerService.php(398): Doctrine\ORM\EntityManager-\>remove(Object(Shopware\Models\Plugin\Plugin)) #19 Shopware/Plugins/Default/Backend/PluginManager/Controllers/Backend/PluginManager.php(56): Shopware\Bundle\PluginInstallerBundle\Service\InstallerService-\>refreshPluginList() #20 Enlight/Controller/Action.php(150): Shopware\_Controllers\_Backend\_PluginManager-\>preDispatch() #21 Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #22 Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #23 Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #24 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #25 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #26 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #27 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #28 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #29 {main}
[/code] Woran kann das liegen? Grüße
Kann mir hier keiner helfen?
Auch bei mir ladet der Plugin Manager nicht! Fehlermeldung: SyntaxError: Unexpected token < at http://www.juweliermeder.de/engine/Shop … 22:18:5361 at Object.Ext.globalEval (http://www.juweliermeder.de/engine/Shop … 22:18:5369) at Ext.Ajax.request.success (http://www.juweliermeder.de/backend/bas … 3489:477:5) at Object.Ext.apply.callback (http://www.juweliermeder.de/engine/Shop … 2:18:67496) at Ext.define.onComplete (http://www.juweliermeder.de/engine/Shop … :18:422670) at Ext.define.onStateChange (http://www.juweliermeder.de/engine/Shop … :18:422314) at XMLHttpRequest. (http://www.juweliermeder.de/engine/Shop … 2:18:17406)
Kann mir jemand weiterhelfen?
Meine PHP Version ist 5.6
