Fehler: Column not found: 1054 Unknown column 'phone' in 'field list' in
Hallo Zusammen,
kann mir vielleicht jemand sagen was diese Fehlermeldung bedeutet?
ERROR
Message:
 PDOException: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'phone' in 'field list' in /www/htdocs/v159636/neuer\_shop/engine/Library/Zend/Db/Statement/Pdo.php:219
 Stack trace:
 #0 /www/htdocs/v159636/neuer\_shop/engine/Library/Zend/Db/Statement/Pdo.php(219): PDOStatement-\>execute(Array)
 #1 /www/htdocs/v159636/neuer\_shop/engine/Library/Zend/Db/Statement.php(297): Zend\_Db\_Statement\_Pdo-\>\_execute(Array)
 #2 /www/htdocs/v159636/neuer\_shop/engine/Library/Zend/Db/Adapter/Abstract.php(470): Zend\_Db\_Statement-\>execute(Array)
 #3 /www/htdocs/v159636/neuer\_shop/engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(232): Zend\_Db\_Adapter\_Abstract-\>query('\n        INSERT...', Array)
 #4 /www/htdocs/v159636/neuer\_shop/engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(96): Zend\_Db\_Adapter\_Pdo\_Abstract-\>query('\n        INSERT...', Array)
 #5 /www/htdocs/v159636/neuer\_shop/engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(131): Enlight\_Components\_Db\_Adapter\_Pdo\_Mysql-\>query('\n        INSERT...', Array)
 #6 /www/htdocs/v159636/neuer\_shop/engine/Shopware/Core/sOrder.php(1130): Enlight\_Components\_Db\_Adapter\_Pdo\_Mysql-\>executeUpdate('\n        INSERT...', Array)
 #7 /www/htdocs/v159636/neuer\_shop/engine/Shopware/Core/sOrder.php(773): sOrder-\>sSaveShippingAddress(Array, '18')
 #8 /www/htdocs/v159636/neuer\_shop/engine/Shopware/Controllers/Frontend/Checkout.php(844): sOrder-\>sSaveOrder()
 #9 /www/htdocs/v159636/neuer\_shop/engine/Shopware/Controllers/Frontend/Checkout.php(375): Shopware\_Controllers\_Frontend\_Checkout-\>saveOrder()
 #10 /www/htdocs/v159636/neuer\_shop/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Frontend\_Checkout-\>finishAction()
 #11 /www/htdocs/v159636/neuer\_shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight\_Controller\_Action-\>dispatch('finishAction')
 #12 /www/htdocs/v159636/neuer\_shop/engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #13 /www/htdocs/v159636/neuer\_shop/engine/Shopware/Kernel.php(189): Enlight\_Controller\_Front-\>dispatch()
 #14 /www/htdocs/v159636/neuer\_shop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #15 /www/htdocs/v159636/neuer\_shop/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #16 /www/htdocs/v159636/neuer\_shop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #17 /www/htdocs/v159636/neuer\_shop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(275): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
 #18 /www/htdocs/v159636/neuer\_shop/engine/Shopware/Components/HttpCache/AppCache.php(143): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
 #19 /www/htdocs/v159636/neuer\_shop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(206): Shopware\Components\HttpCache\AppCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
 #20 /www/htdocs/v159636/neuer\_shop/engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #21 /www/htdocs/v159636/neuer\_shop/shopware.php(118): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #22 {main}
 Next Zend\_Db\_Statement\_Exception: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'phone' in 'field list' in /www/htdocs/v159636/neuer\_shop/engine/Library/Zend/Db/Statement/Pdo.php:224
Time:
 2017-11-06T17:03:28.184801+0100
Channel:
 core
request:
     "uri": "/checkout/finish",
     "method": "POST",
     "query": {
         "module": "frontend",
         "controller": "checkout",
         "action": "finish"
     "post": {
         "sComment": "",
         "sAGB": "on",
         "\_\_csrf\_token": "RXI8yyYeqOz5K0RJH8eZibqlLZK6Ax"
session:
 No session data available
shopId:
 1
shopName:
 Deutsch
