Fehler beim Theme Watcher / Hot Reload von Shopware 6
ich habe leider ein Problem mit dem Hot Reload von Shopware 6.
Sobald ich im Hauptverzeichis bin/watch-storefront ausführe, bekomme ich den folgenden Fehler:
Nochmal als Text:
Start theme compilation
 Compiling theme for sales channel for : dfe51958c14742b392ed3bb3cefde903
 ! [NOTE] Took 6.787597 seconds
 Compiling theme for sales channel for : 6b263f89abe24f94a287638bb66b94fc
 ! [NOTE] Took 6.197231 seconds
 Compiling theme for sales channel for : f8cbcc5ebad342fdb712d8129cdfa3d7
 ! [NOTE] Took 6.599494 seconds
> sw-next-storefront@1.0.0 hot-proxy /var/www/html/vendor/shopware/storefront/Resources/app/storefront
> NODE_ENV=development MODE=hot node ./build/start-hot-reload.js
(node:2095) UnhandledPromiseRejectionWarning: Error: Cannot find module 'webpack'
Require stack:
- /var/www/html/vendor/shopware/storefront/Resources/app/storefront/build/live-reload-server/index.js
- /var/www/html/vendor/shopware/storefront/Resources/app/storefront/build/start-hot-reload.js
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    at Module.require (internal/modules/cjs/loader.js:887:19)
    at require (internal/modules/cjs/helpers.js:74:18)
    at /var/www/html/vendor/shopware/storefront/Resources/app/storefront/build/live-reload-server/index.js:7:25
    at new Promise (<anonymous>)
    at createLiveReloadServer (/var/www/html/vendor/shopware/storefront/Resources/app/storefront/build/live-reload-server/index.js:6:12)
    at Object.<anonymous> (/var/www/html/vendor/shopware/storefront/Resources/app/storefront/build/start-hot-reload.js:5:16)
    at Module._compile (internal/modules/cjs/loader.js:999:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
(node:2095) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
(node:2095) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
www-data@8a547c5ad9d7:~/html$ bin/console theme:build
Kann mir da jemand weiterhelfen?
Beste Grüße,
Nils
Gleiches Problem hier. Shopware normal installiert. (Nicht die dev Methode mit platform clone)
Erhalte den gleichen Fehler.
Hier ebenso. Habt ihr in der Zwischenzeit eine Lösung gefunden? @nils2 @mlo
Die Fehlermeldung sagt aus, dass Webpack auf dem System nicht installiert ist.
Hatte eben das selbe Problem.
Mit Node JS 16.10.0 und NPM 8.0 funktioniert es. Nutze nvm um deine Node Version zu wechseln und starte erstmal mit den Commands: build-administrator und build-storefront. Darauf hin sollten die Watcher Befehle laufen.
Hey, ich stehe vor dem selben Problem.
Ich arbeite in Docker auf meinem M1 Mac und versuche es gerade mit deinen Node und NPM Versionen. Der build-administration command schlägt allerdings fehl mit folgendem Fehler:
pm ERR! code 1
npm ERR! path /srv/www/htdocs/shop/vendor/shopware/administration/Resources/app/administration/node_modules/puppeteer
npm ERR! command failed
npm ERR! command sh -c node install.js
npm ERR! The chromium binary is not available for arm64.
npm ERR! If you are on Ubuntu, you can install with:
npm ERR!
npm ERR!  sudo apt install chromium
npm ERR!
npm ERR!
npm ERR!  sudo apt install chromium-browser
npm ERR!
npm ERR! /srv/www/htdocs/shop/vendor/shopware/administration/Resources/app/administration/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserFetcher.js:119
npm ERR!                     throw new Error();
npm ERR!                     ^
npm ERR!
npm ERR! Error
npm ERR!     at /srv/www/htdocs/shop/vendor/shopware/administration/Resources/app/administration/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserFetcher.js:119:27
npm ERR!     at FSReqCallback.oncomplete (node:fs:198:21)
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2023-03-16T10_19_42_692Z-debug.log
Und die entsprechenden Chromium Pakete lassen sich aber auch nicht installieren, auf Grund von amd64 / arm64 Architektur-Problemen.
Jemand hier eine Idee, wie man da weiterkommt?
vielleicht hilft das hier weiter:
Guter Hinweis, danke.
HomeBrew kam nicht in Frage da innerhalb von ubuntu docker image, aber selbst installieren war der Trick.
Am Ende hats ein vergessenes sudo apt-get update gerichtet…
Manchmal ist es auch einfach was dummes einfaches ;).
