Hallo Liebe Comunity,
leider weis ich nicht weiter. Ich erhalte beim Checkout/Confirm die Tolle Ups Fehlermeldung. Aber ich komme nicht auf die Ursache. Auf der Testumgebung geht alles. Aber im Liveshop nicht. Alle Versionen etc. sind identisch:
SmartyCompilerException in /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php:657 Stack trace:
#0 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3144): Smarty_Internal_TemplateCompilerBase->trigger_template_error()
#1 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3209): Smarty_Internal_Templateparser->yy_syntax_error(10, ‘\xC2’)
#2 /engine/Library/Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, ‘\xC2’)
#3 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(’{if\xC2\xA0$sBasketIt…’)
#4 /engine/Library/Smarty/sysplugins/smarty_internal_template.php(187): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Enlight_Template_Default))
#5 /engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php(155): Smarty_Internal_Template->compileTemplateSource()
#6 /engine/Library/Smarty/sysplugins/smarty_internal_template.php(286): Smarty_Internal_TemplateBase->fetch(Object(Enlight_Template_Default), NULL, NULL, NULL, false, false, true)
#7 /var/www/shopware_live/live/var/cache/production_201810301443/templates/frontend_Responsive_de_DE_1_secure/01/1d/90/011d902e25f70d06097c75e760c42022d77c1804.snippet.confirm_item_product.tpl.php(187): Smarty_Internal_Template->getSubTemplate(‘string:{if\xC2\xA0$sB…’, NULL, ‘frontend_Respon…’, NULL, NULL, Array, 0)
#8 /var/www/shopware_live/live/var/cache/production_201810301443/templates/frontend_Responsive_de_DE_1_secure/01/1d/90/011d902e25f70d06097c75e760c42022d77c1804.snippet.confirm_item_product.tpl.php(55): content_5c169497f24981_64551128(Object(Enlight_Template_Default))
#9 /engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php(180): content_5c1694980bcfb4_83660662(Object(Enlight_Template_Default))
#10 /engine/Library/Smarty/sysplugins/smarty_internal_template.php(286): Smarty_Internal_TemplateBase->fetch(Object(Enlight_Template_Default), NULL, NULL, NULL, false, false, true)
#11 /var/www/shopware_live/live/var/cache/production_201810301443/templates/frontend_Responsive_de_DE_1_secure/54/e8/42/54e842791ef8509b99f29a5d73bfa0e83b5edf55.snippet.index.tpl.php(3143): Smarty_Internal_Template->getSubTemplate(‘frontend/checko…’, NULL, ‘frontend_Respon…’, NULL, NULL, Array, 0)
#12 /var/www/shopware_live/live/var/cache/production_201810301443/templates/frontend_Responsive_de_DE_1_secure/54/e8/42/54e842791ef8509b99f29a5d73bfa0e83b5edf55.snippet.index.tpl.php(1353): content_5c169497b74102_79238200(Object(Enlight_Template_Default))
#13 /engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php(180): content_5c169497ecd144_83126629(Object(Enlight_Template_Default))
#14 /engine/Library/Enlight/View/Default.php(300): Smarty_Internal_TemplateBase->fetch()
#15 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default))
#16 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#17 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
#18 /engine/Library/Enlight/Event/Handler/Default.php(91): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs))
#19 /engine/Library/Enlight/Event/EventManager.php(220): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#20 /engine/Library/Enlight/Controller/Action.php(235): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Object(Enlight_Controller_ActionEventArgs))
#21 /engine/Library/Enlight/Controller/Dispatcher/Default.php(548): Enlight_Controller_Action->dispatch(‘confirmAction’)
#22 /engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#23 /engine/Shopware/Kernel.php(202): Enlight_Controller_Front->dispatch()
#24 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#25 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#26 /engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#27 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(420): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#28 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(317): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#29 /engine/Shopware/Components/HttpCache/AppCache.php(189): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#30 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#31 /engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#32 /var/www/shopware_live/live/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#33 {main}
hoffe Ihr könnt mir helfen.
