Hallo!
Habe folgendes problemm!
Nach dem ich den Profiler Plugin deinstalliere komm folgendes Fehler:
Fatal error : Uncaught SmartyException: Unknown path /home/www/Shopware/themes/Frontend/Bare/engine/Shopware/Plugins/Community/Frontend/TcinnModernTheme/Themes/Frontend/ModernTheme/frontend/index/header_minimal.tpl in file engine/Shopware/Plugins/Community/Frontend/TcinnModernTheme/Themes/Frontend/ModernTheme/frontend/index/header_minimal.tpl in /home/www/Shopware/engine/Library/Smarty/sysplugins/smarty_resource.php:471 Stack trace: #0 /home/www/Shopware/engine/Library/Enlight/Template/Plugins/resource.parent.php(55): Smarty_Resource->buildFilepath(Object(Smarty_Template_Source), Object(Enlight_Template_Default)) #1 /home/www/Shopware/engine/Library/Enlight/Template/Plugins/resource.parent.php(79): Smarty_Resource_Parent->buildFilepath(Object(Smarty_Template_Source), Object(Enlight_Template_Default)) #2 /home/www/Shopware/engine/Library/Smarty/sysplugins/smarty_resource.php(303): Smarty_Resource_Parent->populate(Object(Smarty_Template_Source), Object(Enlight_Template_Default)) #3 /home/www/Shopware/engine/Library/Smarty/sy in /home/www/Shopware/engine/Library/Smarty/sysplugins/smarty_resource.php on line 471
Kann mir vielleicht jemand dabei helfen?
Vielen dank im voraus!
MfG. Anatoli
