Hi guys,
I’ve made a plugin to extend the buttons on the orders listing page in the administration.
As soon as I load the Backend I get a error box with the following error:
The content of the backend/arv_extend_order/view/list/filter.js reads as follows:
//{block name="backend/order/view/list/filter"}
// {$smarty.block.parent}
Ext.define('Shopware.apps.ArvExtendOrder.view.list.Filter', {
override: 'Shopware.apps.Order.view.list.Filter',
createFilterButtons: function () {
// shortend for readability reasons
//{/block}
If I remove the 2nd line in question, then I get a different error message:
<br />
<b>Fatal error</b>: Uncaught SmartyException: Unable to load template snippet 'backend/arv_extend_order/controller/arv_order_controller.js' in 'backend/order/app.js|backend/arv_extend_order/app.js' in /var/www/html/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php:127
The content of the backend/arv_extend_order/controller/arv_order_controller.js:
//{block name="backend/order/controller/filter"}
Ext.define('Shopware.apps.ArvExtendOrder.controller.Filter', {
override: 'Shopware.apps.Order.controller.Filter',
init: function () {
//{/block}
The content of the backend/arv_extend_order/app.js:
//{block name="backend/order/application"}
// {include file="backend/arv_extend_order/controller/arv_order_controller.js"}
// {include file="backend/arv_extend_order/view/list/filter.js"}
//{/block}
Can you help me fix this? I have been trying for ages…
