Error while authentification with the Shopware Account Test-Instance
Hello to everybody,
we got some problem with the Shopware [AppTemplate] (GitHub - shopware/AppTemplate) and the Shopware 6 Test-Instance (The instance to test bevor you give an App to the Review).
When trying to authenticate with the Shopware 6 app test environment to send a request to the Shopware instance, the core code of the AppTemplate throws an exception. This is thrown by a 302 Http status code:
GuzzleHttp\Psr7\Response^ {#160
  -reasonPhrase: "Found"
  -statusCode: 302
  -headers: array:6 [
    "Content-Length" => array:1 [
      0 => "138"
    "Content-Type" => array:1 [
      0 => "text/html"
    "Date" => array:1 [
      0 => "Fri, 19 Aug 2022 13:16:47 GMT"
    "Location" => array:1 [
      0 => "http://xxx-dxifv.sw-testenvironment.de/shop/public/"
    "Server" => array:1 [
      0 => "nginx"
    "Vary" => array:1 [
      0 => "Accept-Encoding"
  -headerNames: array:6 [
    "content-length" => "Content-Length"
    "content-type" => "Content-Type"
    "date" => "Date"
    "location" => "Location"
    "server" => "Server"
    "vary" => "Vary"
  -protocol: "1.1"
  -stream: GuzzleHttp\Psr7\Stream^ {#156
    -stream: stream resource {@242
      wrapper_type: "PHP"
      stream_type: "TEMP"
      mode: "w+b"
      unread_bytes: 0
      seekable: true
      uri: "php://temp"
      options: []
    -size: null
    -seekable: true
    -readable: true
    -writable: true
    -uri: "php://temp"
    -customMetadata: []
PHP Warning:  Trying to access array offset on value of type null in /vendor/shopware/app-bundle/src/Client/Credentials.php on line 22
PHP Warning:  Trying to access array offset on value of type null in /vendor/shopware/app-bundle/src/Client/Credentials.php on line 23
TypeError {#163
  #message: "Shopware\AppBundle\Client\Credentials::__construct(): Argument #1 ($tokenType) must be of type string, null given, called in /vendor/shopware/app-bundle/src/Client/Credentials.php on line 23"
  #code: 0
  #file: "./vendor/shopware/app-bundle/src/Client/Credentials.php"
  #line: 9
  trace: {
    ./vendor/shopware/app-bundle/src/Client/Credentials.php:9 { …}
    ./vendor/shopware/app-bundle/src/Client/Credentials.php:23 { …}
    ./vendor/shopware/app-bundle/src/Client/ShopClient.php:94 { …}
    ./vendor/shopware/app-bundle/src/Client/ShopClient.php:70 { …}
    ./vendor/shopware/app-bundle/src/Client/ShopClient.php:32 { …}
    ./src/Helper/ShopFunctions.php:45 {
      App\Helper\ShopFunctions::getCurrencies(ShopClient $client)^
      ›     'api/search/currency',
      ›     body: json_encode([])
    ./src/Command/DiscountCommand.php:55 { …}
    ./vendor/symfony/console/Command/Command.php:299 { …}
    ./vendor/symfony/console/Application.php:1006 { …}
    ./vendor/symfony/framework-bundle/Console/Application.php:96 { …}
    ./vendor/symfony/console/Application.php:295 { …}
    ./vendor/symfony/framework-bundle/Console/Application.php:82 { …}
    ./vendor/symfony/console/Application.php:167 { …}
    ./vendor/symfony/runtime/Runner/Symfony/ConsoleApplicationRunner.php:56 { …}
    ./vendor/autoload_runtime.php:35 { …}
    ./bin/console_2:11 { …}
The calling code:
static function getCurrencies(ShopClient $client)
        $currencyResponse = $client->sendRequest(new Request(
            'POST',
        return json_decode($currencyResponse->getBody()->getContents(), true);
We already opened an issue at Github:
Thanks for looking at!
