Error when trying to build storefront
Hello,
We are trying to build storefront using these commands:
php bin/console bundle:dump
PROJECT_ROOT= __ABSOLUTE_PATH_TO_PROJECT_ROOT__ / npm --prefix vendor/shopware/storefront/Resources/ run production
php bin/console theme:compile
php bin/console assets:install
But we get this error even if we install the module (npm install app-module-path --save);
Error: Cannot find module 'app-module-path'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    at Module.require (internal/modules/cjs/loader.js:690:17)
Does anyone have an ideea how we can solve this?
Thank you in advance.
Best regards,
Sorin
@SorinSologics2019 schrieb:
Hello,
PROJECT_ROOT= ABSOLUTE_PATH_TO_PROJECT_ROOT / npm --prefix vendor/shopware/storefront/Resources/ run production
Error: Cannot find module ‚app-module-path‘
Best regards,
Sorin
Did you find the solution for it?
I got the same error. Any solutions?
I stumbled across the same error.
It seems that the storefront depends on some libs, which are included in the admistration parts.
So you need to build the administration first
bin/build-administration.sh
before building the storefront
bin/build-storefront.sh
Hello,
We are trying to build storefront using these myprepaidcenter commands:
Facing the same problem, please help me.
Hello.
You should use the psh commands like ./psh.phar administration:build and storefront:build.
But before running these you need to run administration:init and storefront:init
Regards,
Sorin
@SorinSologics2019‍
but this ./psh.phar commands only run in develop mode, doesn’t they?
what about if I want to build my storefront in production mode?
not bad, it seems that
now works with the production version of Shopware, i.e. with install_6.1.4_1584369563.
In my plugin i can use Sass-Files to change the Theme, thanks.
(… or was that more of a coincidence and Shopware doesn’t even want it…)
I also think that this should be possible in any case, also in the future, not that Shopware will change anything there again. I would not like to use the development version. I want to develop with the same version that is live.
Best regards,
Werner.
bin/console theme:compile doesn’t only compile the scss-File’s.
Is it possible to compile the Javascript-Plugin’s, that is the extension of the Shopware 6 Plugin class.
I’m using the production environment.
Thanks and best regards,
Werner.
