ERROR PayPal Plus CSRFToken
 Hallo habe Shopware 5.2.20 und PayPalPlus 1.2.6 Ich habe immer diese Fehler. Bzw Kunden können schlecht einkaufen. Login bringt ein "UPS...." und Anmeldung :::::::::::Fehler:::::::::::::::: exception 'Shopware\Components\CSRFTokenValidationException' with message 'The provided X-CSRF-Token for path "/paypalplus/index/webhooks/" is invalid. Please go back, reload the page and try again.' in /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/engine/Shopware/Components/CSRFTokenValidator.php:158
 Stack trace:
 #0 [internal function]: Shopware\Components\CSRFTokenValidator-\>checkFrontendTokenValidation(Object(Enlight\_Controller\_ActionEventArgs))
 #1 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs))
 #2 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
 #3 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/engine/Library/Enlight/Controller/Action.php(143): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
 #4 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('indexAction')
 #5 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #6 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/engine/Shopware/Kernel.php(180): Enlight\_Controller\_Front-\>dispatch()
 #7 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #8 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #9 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #10 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(275): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
 #11 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/engine/Shopware/Components/HttpCache/AppCache.php(133): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
 #12 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(206): Shopware\Components\HttpCache\AppCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
 #13 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #14 /var/www/vhosts/lvps92-51-165-xx.dedicated.hosteurope.de/shopware/shopware.php(117): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #15 {main}
 2017-03-15T17:09:25.577670+0100
 core
     "uri": "/paypalplus/index/webhooks/",
     "method": "POST",
     "query": {
         "module": "frontend",
         "controller": "paypalplus",
         "action": "index",
         "webhooks": ""
     "post": []
https://forum.shopware.com/discussion/comment/189685/#Comment_189685
https://developers.shopware.com/developers-guide/csrf-protection/?_ga=1.183815846.1488502039.1478196289#disable-the-protection
