Hi everyone, I hope you’re doing well!
I’ve just started developing extensions on Shopware 6, and for the past two weeks, I’ve been facing a persistent problem: I can’t retrieve the new values when my fields are modified. Whether I’m using v-model, @change, :change, @input, or :input.
The various functions are executed correctly when the page loads (I checked using console.log), but once the page is loaded, I no longer have access to these functions. When inspecting, I notice that functions for these events exist and are the same for all:
e => {
if (e._vts) {
if (e._vts <= n.attached) return
} else e._vts = Date.now();
t2(function(e, t) {
if (!F(t)) return t; {
let n = e.stopImmediatePropagation;
return e.stopImmediatePropagation = () => {
n.call(e), e._stopped = !0
}, t.map(e => t => !t._stopped && e && e(t))
}(e, n.value), t, 5, [e])
I should mention that I didn’t create this; it’s entirely generated automatically.
The complete twig file for the page is:
<sw-page class="custom-product-detail">
<template #smart-bar-actions>
<sw-button :routerLink="{ name: 'custom.product.index' }">
{{ $tc('custom-product.detail.canceButtonText') }}
</sw-button>
<sw-button-process
:isLoading="isLoading"
:processSuccess="processSuccess"
variant="primary"
@process-finsih="saveFinish"
@click="onClickSave">
{{ $tc('custom-product.detail.saveButtonText') }}
</sw-button-process>
</template>
<template #content>
<sw-card-view>
<sw-card v-if="custom_product" :isLoading="isLoading">
<sw-container columns="1fr" gap=30px>
<sw-text-field
v-model="custom_product.name"
:label="$tc('custom-product.detail.customProductLabelText')"
placeholder="Entrez le titre du formulaire"
@input="setCustomProductLabel"
></sw-text-field>
<sw-checkbox-field
v-model="custom_product.in_step"
:label="$tc('custom-product.detail.customProductInStepLabel')"
></sw-checkbox-field>
</sw-container>
<sw-entity-multi-select
v-if="custom_product.products"
v-model="custom_product.products"
:label="$tc('custom-product.detail.selectProductLabel')"
></sw-entity-multi-select>
</sw-card>
</sw-card-view>
</template>
</sw-page>
and the complete index.js file for the same page:
import template from './custom-product-detail.html.twig'
const { Component, Mixin } = Shopware;
Component.register('custom-product-detail', {
template,
inject: [
'repositoryFactory'
mixins: [
Mixin.getByName('notification')
metaInfo() {
return {
title: this.$createTitle(),
data() {
return {
custom_product_repository: null,
custom_product : null,
isLoading: false,
processSuccess:false
watch: {
'custom_product.name' : function (newValue) {
console.log('Nouvelle valeur:', newValue)
this['custom_product.name'] = newValue
created(){
this.createdComponent()
methods: {
setCustomProductLabel(input) {
const newValue = input.target.value || "null"
this.custom_product.name = newValue
createdComponent(){
this.custom_product_repository = this.repositoryFactory.create('custom_product')
this.getCustomProduct()
getCustomProduct(){
this.custom_product_repository.get(this.$route.params.id, Shopware.Context.api).then((entity) => {
this.custom_product = entity
onClickSave(){
this.isLoading=true;
this.custom_product_repository.save(thsi.custom_product, Shopware.Context.api).then(() => {
this.isLoading = false
this.processSuccess = true
}).catch((exception) => {
this.createNotificationError({
title: this.$tc('custom-product.detail.errorTitle'),
message: exception
saveFinish(){
this.processSuccess = false
I’m using Shopware 6.6.0, installed with Docker (Dockware).
I also want to mention that I’ve tested with checkboxes, switch-buttons, and input-text fields, but even the console.log statements don’t appear. In the example above, I don’t have @change, but I’ve tried it, as well as :change.
Thank you very much for your time; any advice would be greatly appreciated.
