Error bei Get manufacturer
Liebes Forum :slight_smile: :slight_smile:
Ich bekomme im Backend folgende Fehlermeldung:
exception ‚Assert\InvalidArgumentException‘ with message ‚Value „“ is not an integer or a number castable to integer.‘ in /var/www/vhosts/meinshop.de/httpdocs/vendor/beberlei/assert/lib/Assert/Assertion.php:212
Stack trace:
#0 /var/www/vhosts/meinshop.de/httpdocs/vendor/beberlei/assert/lib/Assert/Assertion.php(384): Assert\Assertion::createException(‚‘, ‚Value „“ is not…‘, 12, NULL)
#1 [internal function]: Assert\Assertion::integerish(‚‘)
#2 /var/www/vhosts/meinshop.de/httpdocs/vendor/beberlei/assert/lib/Assert/Assertion.php(1494): call_user_func_array(Array, Array)
#3 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Bundle/SearchBundle/Condition/ManufacturerCondition.php(47): Assert\Assertion::__callStatic(‚allIntegerish‘, Array)
#4 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Bundle/SearchBundle/Condition/ManufacturerCondition.php(47): Assert\Assertion::allIntegerish(Array)
#5 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Bundle/SearchBundle/CriteriaRequestHandler/CoreCriteriaRequestHandler.php(185): Shopware\Bundle\SearchBundle\Condition\ManufacturerCondition->__construct(Array)
#6 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Bundle/SearchBundle/CriteriaRequestHandler/CoreCriteriaRequestHandler.php(114): Shopware\Bundle\SearchBundle\CriteriaRequestHandler\CoreCriteriaRequestHandler->addManufacturerCondition(Object(Enlight_Controller_Request_RequestHttp), Object(Shopware\Bundle\SearchBundle\Criteria))
#7 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Bundle/SearchBundle/StoreFrontCriteriaFactory.php(280): Shopware\Bundle\SearchBundle\CriteriaRequestHandler\CoreCriteriaRequestHandler->handleRequest(Object(Enlight_Controller_Request_RequestHttp), Object(Shopware\Bundle\SearchBundle\Criteria), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#8 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Bundle/SearchBundle/StoreFrontCriteriaFactory.php(133): Shopware\Bundle\SearchBundle\StoreFrontCriteriaFactory->createCriteriaFromRequest(Object(Enlight_Controller_Request_RequestHttp), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#9 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Controllers/Frontend/Listing.php(59): Shopware\Bundle\SearchBundle\StoreFrontCriteriaFactory->createListingCriteria(Object(Enlight_Controller_Request_RequestHttp), Object(Shopware\Bundle\StoreFrontBundle\Struct\ShopContext))
#10 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Frontend_Listing->manufacturerAction()
#11 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚manufacturerAct…‘)
#12 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#13 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Kernel.php(177): Enlight_Controller_Front->dispatch()
#14 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#15 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#16 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(444): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#17 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#18 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#19 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#20 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#21 /var/www/vhosts/meinshop.de/httpdocs/shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#22 {main}
2017-07-12T17:38:51.580867+0200
core
    „uri“: „/listing/manufacturer/sSupplier/“,
    „method“: „GET“,
    „query“: {
        „module“: „frontend“,
        „controller“: „listing“,
        „action“: „manufacturer“,
        „sSupplier“: „“
    „post“:
No session data available
1
meinshop
Das ist zwar nicht ganz so schlimm, da es kein Kunde merkt und man es im Backend auch nicht mitbekommt, aber ich würde trotzdem gerne einmal wissen, was da los ist.
Ähnliche Fehlermeldungen bekomme ich auch bei anderen Backendabfragen, zum Beispiel bei Get Visitors.
Liebe Grüße
Kerstin :slight_smile:
Irgendwie ein Problem mit Hersteller? Irgendwo einen gelöscht der noch zu einem Artikel zugeordnet ist? Wie siehts denn in der Datenbank (s_articles_supplier) aus, alles korrekt?
Schau mal hier wurde exakt das schon mal abgehndelt.
