Hi There,
I try to create dynamic product groups in shopware 6.4 API
I need to create around 500 dynamic product groups, so adding them manual is not an option.
I grabbed the code from the swagger ui and modified it to the following code
"data": {
"name": "this is created in postman",
"type": "product_stream",
"filters": [
"productStreamId": "c4abf1df47e1428185c52ba44136afe4",
"type": "multi",
"operator": "OR",
"position": 0,
"queries": [
"parentId": "7cd6064a3d364a6fa9cfb3918a2e7704",
"type": "multi",
"operator": "AND",
"position": 0,
"queries": [
"parentId": "5e95e2506b1a4883bfd0bc281421c339",
"type": "equals",
"field": "properties.name",
"value": "T-shirts",
"position": 0,
"id": "4d4114c994ce46c480f616aa57208c06"
"id": "5e95e2506b1a4883bfd0bc281421c339"
"id": "7cd6064a3d364a6fa9cfb3918a2e7704"
"id": "c4abf1df47e1428185c52ba44136afe4"
When i post this or the unmodified swagger example code i get the following message.
"errors": [
"code": "c1051bb4-d103-4f74-8988-acbcafc7fdc3",
"status": "400",
"detail": "Deze waarde mag niet leeg zijn.",
"template": "This value should not be blank.",
"meta": {
"parameters": {
"{{ value }}": "null"
"source": {
"pointer": "/0/translations/2fbb5fe2e29a4d70aa5854ce7ce3e20b/name"
I did some research on the errorcode and pointer, But so far no solution.
But it should be something of a translations name.
I’ve installed the shopware language pack, and activated dutch. The main install Language is English.
How can i resolve this issue?
Thanks!
