Guten Abend Leute,
habe seit mehreren Tagen das Problem, das meine Seite nicht aufrufbar sind! lade ich diese neu gehts dann mal wieder nicht.
Zeitlich sind diese über den ganzen Tag verteilt und im Backend Log finde ich diese Meldung:
UPS! EIN FEHLER IST AUFGETRETEN!
DIE NACHFOLGENDEN HINWEISE SOLLTEN IHNEN WEITERHELFEN.
[SEMANTICAL ERROR] THE ANNOTATION “@\DOCTRINE\ORM\MAPPING\ENTITY” IN CLASS BIBUBADGESKONFIGURATOR\MODELS\BIBUBADGE DOES NOT EXIST, OR COULD NOT BE AUTO-LOADED. IN VENDOR/DOCTRINE/ANNOTATIONS/LIB/DOCTRINE/COMMON/ANNOTATIONS/ANNOTATIONEXCEPTION.PHP ON LINE 54
STACK TRACE:
#0 VENDOR/DOCTRINE/ANNOTATIONS/LIB/DOCTRINE/COMMON/ANNOTATIONS/DOCPARSER.PHP(730): DOCTRINE\COMMON\ANNOTATIONS\ANNOTATIONEXCEPTION::SEMANTICALERROR('THE ANNOTATION ...') #1 VENDOR/DOCTRINE/ANNOTATIONS/LIB/DOCTRINE/COMMON/ANNOTATIONS/DOCPARSER.PHP(663): DOCTRINE\COMMON\ANNOTATIONS\DOCPARSER-\>ANNOTATION() #2 VENDOR/DOCTRINE/ANNOTATIONS/LIB/DOCTRINE/COMMON/ANNOTATIONS/DOCPARSER.PHP(354): DOCTRINE\COMMON\ANNOTATIONS\DOCPARSER-\>ANNOTATIONS() #3 VENDOR/DOCTRINE/ANNOTATIONS/LIB/DOCTRINE/COMMON/ANNOTATIONS/ANNOTATIONREADER.PHP(218): DOCTRINE\COMMON\ANNOTATIONS\DOCPARSER-\>PARSE('/\*\*\N \* BIBUBADG...', 'CLASS BIBUBADGE...') #4 VENDOR/DOCTRINE/ANNOTATIONS/LIB/DOCTRINE/COMMON/ANNOTATIONS/CACHEDREADER.PHP(79): DOCTRINE\COMMON\ANNOTATIONS\ANNOTATIONREADER-\>GETCLASSANNOTATIONS(OBJECT(REFLECTIONCLASS)) #5 VENDOR/DOCTRINE/ORM/LIB/DOCTRINE/ORM/MAPPING/DRIVER/ANNOTATIONDRIVER.PHP(63): DOCTRINE\COMMON\ANNOTATIONS\CACHEDREADER-\>GETCLASSANNOTATIONS(OBJECT(REFLECTIONCLASS)) #6 VENDOR/DOCTRINE/ORM/LIB/DOCTRINE/ORM/MAPPING/CLASSMETADATAFACTORY.PHP(151): DOCTRINE\ORM\MAPPING\DRIVER\ANNOTATIONDRIVER-\>LOADMETADATAFORCLASS('BIBUBADGESKONFI...', OBJECT(DOCTRINE\ORM\MAPPING\CLASSMETADATA)) #7 VENDOR/DOCTRINE/COMMON/LIB/DOCTRINE/COMMON/PERSISTENCE/MAPPING/ABSTRACTCLASSMETADATAFACTORY.PHP(332): DOCTRINE\ORM\MAPPING\CLASSMETADATAFACTORY-\>DOLOADMETADATA(OBJECT(DOCTRINE\ORM\MAPPING\CLASSMETADATA), NULL, FALSE, ARRAY) #8 VENDOR/DOCTRINE/ORM/LIB/DOCTRINE/ORM/MAPPING/CLASSMETADATAFACTORY.PHP(78): DOCTRINE\COMMON\PERSISTENCE\MAPPING\ABSTRACTCLASSMETADATAFACTORY-\>LOADMETADATA('BIBUBADGESKONFI...') #9 VENDOR/DOCTRINE/COMMON/LIB/DOCTRINE/COMMON/PERSISTENCE/MAPPING/ABSTRACTCLASSMETADATAFACTORY.PHP(216): DOCTRINE\ORM\MAPPING\CLASSMETADATAFACTORY-\>LOADMETADATA('BIBUBADGESKONFI...') #10 VENDOR/DOCTRINE/ORM/LIB/DOCTRINE/ORM/ENTITYMANAGER.PHP(281): DOCTRINE\COMMON\PERSISTENCE\MAPPING\ABSTRACTCLASSMETADATAFACTORY-\>GETMETADATAFOR('BIBUBADGESKONFI...') #11 ENGINE/SHOPWARE/COMPONENTS/MODEL/PROXYAWAREREPOSITORYFACTORY.PHP(56): DOCTRINE\ORM\ENTITYMANAGER-\>GETCLASSMETADATA('BIBUBADGESKONFI...') #12 VENDOR/DOCTRINE/ORM/LIB/DOCTRINE/ORM/ENTITYMANAGER.PHP(698): SHOPWARE\COMPONENTS\MODEL\PROXYAWAREREPOSITORYFACTORY-\>GETREPOSITORY(OBJECT(SHOPWARE\COMPONENTS\MODEL\MODELMANAGER), 'BIBUBADGESKONFI...') #13 CUSTOM/PLUGINS/BIBUBADGESKONFIGURATOR/BIBUBADGESKONFIGURATOR.PHP(243): DOCTRINE\ORM\ENTITYMANAGER-\>GETREPOSITORY('BIBUBADGESKONFI...') #14 CUSTOM/PLUGINS/BIBUBADGESKONFIGURATOR/BIBUBADGESKONFIGURATOR.PHP(116): BIBUBADGESKONFIGURATOR\BIBUBADGESKONFIGURATOR-\>GETBADGES() #15 ENGINE/LIBRARY/ENLIGHT/EVENT/HANDLER/DEFAULT.PHP(91): BIBUBADGESKONFIGURATOR\BIBUBADGESKONFIGURATOR-\>ONPOSTDISPATCHFRONTEND(OBJECT(ENLIGHT\_CONTROLLER\_ACTIONEVENTARGS)) #16 ENGINE/LIBRARY/ENLIGHT/EVENT/EVENTMANAGER.PHP(214): ENLIGHT\_EVENT\_HANDLER\_DEFAULT-\>EXECUTE(OBJECT(ENLIGHT\_CONTROLLER\_ACTIONEVENTARGS)) #17 ENGINE/LIBRARY/ENLIGHT/CONTROLLER/ACTION.PHP(178): ENLIGHT\_EVENT\_EVENTMANAGER-\>NOTIFY('ENLIGHT\_CONTROL...', OBJECT(ENLIGHT\_CONTROLLER\_ACTIONEVENTARGS)) #18 ENGINE/LIBRARY/ENLIGHT/CONTROLLER/DISPATCHER/DEFAULT.PHP(523): ENLIGHT\_CONTROLLER\_ACTION-\>DISPATCH('INDEXACTION') #19 ENGINE/LIBRARY/ENLIGHT/CONTROLLER/FRONT.PHP(223): ENLIGHT\_CONTROLLER\_DISPATCHER\_DEFAULT-\>DISPATCH(OBJECT(ENLIGHT\_CONTROLLER\_REQUEST\_REQUESTHTTP), OBJECT(ENLIGHT\_CONTROLLER\_RESPONSE\_RESPONSEHTTP)) #20 ENGINE/SHOPWARE/KERNEL.PHP(180): ENLIGHT\_CONTROLLER\_FRONT-\>DISPATCH() #21 VENDOR/SYMFONY/HTTP-KERNEL/HTTPCACHE/HTTPCACHE.PHP(487): SHOPWARE\KERNEL-\>HANDLE(OBJECT(ENLIGHT\_CONTROLLER\_REQUEST\_REQUESTHTTP), 1, TRUE) #22 ENGINE/SHOPWARE/COMPONENTS/HTTPCACHE/APPCACHE.PHP(255): SYMFONY\COMPONENT\HTTPKERNEL\HTTPCACHE\HTTPCACHE-\>FORWARD(OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\REQUEST), TRUE, NULL) #23 VENDOR/SYMFONY/HTTP-KERNEL/HTTPCACHE/HTTPCACHE.PHP(444): SHOPWARE\COMPONENTS\HTTPCACHE\APPCACHE-\>FORWARD(OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\REQUEST), TRUE) #24 VENDOR/SYMFONY/HTTP-KERNEL/HTTPCACHE/HTTPCACHE.PHP(344): SYMFONY\COMPONENT\HTTPKERNEL\HTTPCACHE\HTTPCACHE-\>FETCH(OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\REQUEST), TRUE) #25 ENGINE/SHOPWARE/COMPONENTS/HTTPCACHE/APPCACHE.PHP(178): SYMFONY\COMPONENT\HTTPKERNEL\HTTPCACHE\HTTPCACHE-\>LOOKUP(OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\REQUEST), TRUE) #26 VENDOR/SYMFONY/HTTP-KERNEL/HTTPCACHE/HTTPCACHE.PHP(210): SHOPWARE\COMPONENTS\HTTPCACHE\APPCACHE-\>LOOKUP(OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\REQUEST), TRUE) #27 ENGINE/SHOPWARE/COMPONENTS/HTTPCACHE/APPCACHE.PHP(114): SYMFONY\COMPONENT\HTTPKERNEL\HTTPCACHE\HTTPCACHE-\>HANDLE(OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\REQUEST), 2, TRUE) #28 VENDOR/SYMFONY/HTTP-KERNEL/HTTPCACHE/ESI.PHP(278): SHOPWARE\COMPONENTS\HTTPCACHE\APPCACHE-\>HANDLE(OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\REQUEST), 2, TRUE) #29 VAR/CACHE/PRODUCTION\_201702141330/HTML/EN/15/BD/4D80195D053C0A9D6D90EB718B98005744C6D4FD1D68E66859DFFB2AC30F(214): SYMFONY\COMPONENT\HTTPKERNEL\HTTPCACHE\ESI-\>HANDLE(OBJECT(SHOPWARE\COMPONENTS\HTTPCACHE\APPCACHE), '/?MODULE=WIDGET...', '', FALSE) #30 VENDOR/SYMFONY/HTTP-KERNEL/HTTPCACHE/HTTPCACHE.PHP(641): INCLUDE('/SIRAVAAS/WWW.S...') #31 VENDOR/SYMFONY/HTTP-KERNEL/HTTPCACHE/HTTPCACHE.PHP(213): SYMFONY\COMPONENT\HTTPKERNEL\HTTPCACHE\HTTPCACHE-\>RESTORERESPONSEBODY(OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\REQUEST), OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\RESPONSE)) #32 ENGINE/SHOPWARE/COMPONENTS/HTTPCACHE/APPCACHE.PHP(114): SYMFONY\COMPONENT\HTTPKERNEL\HTTPCACHE\HTTPCACHE-\>HANDLE(OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\REQUEST), 1, TRUE) #33 SHOPWARE.PHP(117): SHOPWARE\COMPONENTS\HTTPCACHE\APPCACHE-\>HANDLE(OBJECT(SYMFONY\COMPONENT\HTTPFOUNDATION\REQUEST)) #34 {MAIN}
