Customweb Postfinance Checkout Plugin
wir haben ein Problem mit dem Customweb Postfinance Plugin. Leider sind die gerade bis morgen geschlossen.
Im Frontend erscheinen keine Postfinance Checkout Zahlarten (Kreditkarte, Twint, efinance…)
Im Backend erscheint folgende Fehlermeldung wenn man dein Bestellung mit der Zahlart öffnet.
Ups! An error has occurred! The following hints should help you.
Error 301 connecting to the API (https://www.postfinance-checkout.ch//api/currency/all) :
in custom/plugins/PostFinanceCheckoutPayment/vendor/PostFinanceCheckout/Sdk/lib/ApiClient.php on line 466 Stack trace:
#0 custom/plugins/PostFinanceCheckoutPayment/vendor/PostFinanceCheckout/Sdk/lib/Service/CurrencyService.php(129): PostFinanceCheckout\Sdk\ApiClient->callApi()
#1 custom/plugins/PostFinanceCheckoutPayment/vendor/PostFinanceCheckout/Sdk/lib/Service/CurrencyService.php(80): PostFinanceCheckout\Sdk\Service\CurrencyService->allWithHttpInfo()
#2 custom/plugins/PostFinanceCheckoutPayment/Components/Provider/Currency.php(74): PostFinanceCheckout\Sdk\Service\CurrencyService->all()
#3 custom/plugins/PostFinanceCheckoutPayment/Components/Provider/AbstractProvider.php(95): PostFinanceCheckoutPayment\Components\Provider\Currency->fetchData()
#4 custom/plugins/PostFinanceCheckoutPayment/Components/Provider/AbstractProvider.php(112): PostFinanceCheckoutPayment\Components\Provider\AbstractProvider->PostFinanceCheckoutPayment\Components\Provider\{closure}()
#5 custom/plugins/PostFinanceCheckoutPayment/Components/Provider/AbstractProvider.php(96): PostFinanceCheckoutPayment\Components\Provider\AbstractProvider->callApi()
#6 custom/plugins/PostFinanceCheckoutPayment/Components/Provider/AbstractProvider.php(64): PostFinanceCheckoutPayment\Components\Provider\AbstractProvider->loadData()
#7 custom/plugins/PostFinanceCheckoutPayment/Components/Provider/Currency.php(42): PostFinanceCheckoutPayment\Components\Provider\AbstractProvider->find()
#8 custom/plugins/PostFinanceCheckoutPayment/Components/Provider/Currency.php(63): PostFinanceCheckoutPayment\Components\Provider\Currency->find()
#9 custom/plugins/PostFinanceCheckoutPayment/Components/ArrayBuilder/TransactionInfo.php(149): PostFinanceCheckoutPayment\Components\Provider\Currency->getFractionDigits()
#10 custom/plugins/PostFinanceCheckoutPayment/Components/TransactionInfo.php(301): PostFinanceCheckoutPayment\Components\ArrayBuilder\TransactionInfo->build()
#11 custom/plugins/PostFinanceCheckoutPayment/Controllers/Backend/PostFinanceCheckoutPaymentTransaction.php(254): PostFinanceCheckoutPayment\Components\TransactionInfo->buildTransactionInfoAsArray()
#12 engine/Library/Enlight/Controller/Action.php(192): Shopware_Controllers_Backend_PostFinanceCheckoutPaymentTransaction->getTransactionsAction()
#13 engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight_Controller_Action->dispatch()
#14 engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch()
#15 engine/Shopware/Kernel.php(188): Enlight_Controller_Front->dispatch()
#16 vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle()
#17 vendor/symfony/http-kernel/HttpCache/HttpCache.php(453): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle()
#18 engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward()
#19 vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache->forward() #20 engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass()
#21 shopware.php(122): Shopware\Components\HttpCache\AppCache->handle()
#22 {main}
Ich hoffe jemand kennt das Problem?
PHP 7.4
SW 5.6.7
Da Customweb das Problem nicht direkt mit dem Kunden lösen möchte und lieber den Umweg über Postfinance geht, eine Frage,
Kann jemand mit dieser Fehlermeldung was anfangen oder mir übersetzen?
Danke und Gruss.
Ok, scheinbar gibt es eine neue Pluginversion und neue andere Endpunkte bei postfinance.
Da das Plugin nicht über den Store läuft habe ich nur eine Zip-File von Github. Kann mir jemand sagen ob ich das Plugin fürn manuelles Update:
  • komplett deinstallieren - neu installieren ODER
  • die alten Plugindatein mit den neuen überschreiben
kann. Ich will nicht die IDs verlieren.
Danke und Gruss
Die Antwort war die „Plugindaten überschreiben“ für ein Update.
