We are facing issue with shopware front-end and back-end with custom tabs
In-frontEnd
Uncaught Error: The required element „#custom-field-tab-3-pane“ does not exist in parent node!
In BackEnd
Invisible Tabs
Steps to reproduce:
Login to shopware admin and select product and check the specification. There will be custom-tabs in the bottom and some of them will be invisible .
Search the same product in frontend and open console there will be console error as well
Kindly please help us to fix this issue
Thanks
