Custom Captcha not selectable
I created a custom captcha class which has no real implementation yet:
#[Package('storefront')]
class TestCaptcha extends AbstractCaptcha
    final public const CAPTCHA_NAME = 'testCaptcha';
    public function isValid(Request $request, array $captchaConfig): bool
        return true;
    public function getName(): string
        return self::CAPTCHA_NAME;
Before implementing the Captcha itself I want to be able to select it in the administration. It does show up in the select box, but I am unable to select it:
Clicking on „Test Captcha“ does not do anything. The other Captcha implementations can be selected however.
I read Add custom captcha | Shopware Documentation which did not help.
What do I have to do to make the Captcha selectable?
Did you try in the python way ?
You have to add a migration file to extend the system config entry with the key „core.basicInformation.activeCaptchasV2“ with your captcha.
If your captcha need any configuration settings you have to override the template of the sw-settings-captcha-select-v2 admin component to implemet your config fields.
