Hallo zusammen!
Der Warenkorb eines neu installierten Shops (5.2.14) mit modifiziertem Standard-Template hat ewig geladen ohne zu einem Ende zu kommen.
Das Log zeigte einen Error an:
[2017-01-19 12:38:26] core.ERROR: exception ‚Shopware\Components\CSRFTokenValidationException‘ with message ‚The provided X-CSRF-Token for path „/checkout/addArticle“ is invalid. Please go back, reload the page and try again.‘ in /srv/web/domain.com/data/engine/Shopware/Components/CSRFTokenValidator.php:161 Stack trace: #0 [internal function]: Shopware\Components\CSRFTokenValidator->checkFrontendTokenValidation(Object(Enlight_Controller_ActionEventArgs)) #1 /srv/web/domain.com/data/engine/Library/Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs)) #2 /srv/web/domain.com/data/engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs)) #3 /srv/web/domain.com/data/engine/Library/Enlight/Controller/Action.php(143): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs)) #4 /srv/web/domain.com/data/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚addArticleActio…‘) #5 /srv/web/domain.com/data/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #6 /srv/web/domain.com/data/engine/Shopware/Kernel.php(179): Enlight_Controller_Front->dispatch() #7 /srv/web/domain.com/data/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #8 /srv/web/domain.com/data/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #9 /srv/web/domain.com/data/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #10 /srv/web/domain.com/data/vendor/symfony/http-kernel/HttpCache/HttpCache.php(275): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #11 /srv/web/domain.com/data/engine/Shopware/Components/HttpCache/AppCache.php(133): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #12 /srv/web/domain.com/data/vendor/symfony/http-kernel/HttpCache/HttpCache.php(206): Shopware\Components\HttpCache\AppCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #13 /srv/web/domain.com/data/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #14 /srv/web/domain.com/data/shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #15 {main} [] {„uid“:„b56b7ee“}
Nach Deaktivierung des CSRF’s über die config funktioniert alles, aber das ist ja nicht im Sinne des Erfinders.
Was ich probiert habe:
- Alle Plugins sind deaktiviert
- Anderes Template (Bare) bringt keine Besserung
- aktivieren/deaktivieren des Off Canvas Warenkorbs
- Zahlungsarten und Versandkosten sind ok (die hatte ich zuallererst in Verdacht)
PHP ist 5.6.29 - Systeminfo ist komplett grün - MySQL 5.5.53
Wird jemand aus der Fehlermeldung schlauer? Was könnte ich übersehen haben?
In vielerlei Hinsicht ist Shopware sehr einfach. Ein Webshop ansich ist halt eine komplexe Unternehmung.
