OK, jetzt kam er wieder, hier mal das Log, das mir der Shop gesendet hat: Das Log vom Server bekomme ich erst morgen, weil ich die Subdomain nicht für das Log aktiviert hatte. Viielleicht kann man hier ja was erkennen???
CRITICAL
Message:
An exception occurred while executing 'INSERT INTO s\_core\_templates\_config\_elements (type, name, position, default\_value, selection, field\_label, support\_text, allow\_blank, less\_compatible, attributes, container\_id, template\_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)' with params ["theme-media-selection", "mobileLogo", 0, "s:47:\"frontend\/\_public\/src\/img\/logos\/logo--mobile.png\";", "N;", "\_\_smartphone\_\_", null, 1, 0, "a:1:{s:14:\"lessCompatible\";b:0;}", 157, 30]: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '30-mobileLogo' for key 'template\_id\_name'
Time:
2019-04-01T14:44:41.221303+0200
Channel:
core
request:
{ "uri": "/backend/Theme/list?\_dc=1554122678986&page=1&start=0&limit=20&group=%5B%7B%22property%22%3A%22version%22%2C%22direction%22%3A%22DESC%22%7D%5D&sort=%5B%7B%22property%22%3A%22version%22%2C%22direction%22%3A%22DESC%22%7D%5D", "method": "GET", "query": { "\_dc": "1554122678986", "page": "1", "start": "0", "limit": "20", "group": "[{\"property\":\"version\",\"direction\":\"DESC\"}]", "sort": "[{\"property\":\"version\",\"direction\":\"DESC\"}]", "module": "backend", "controller": "Theme", "action": "list" }, "post": [] }
shop:
No shop data available
session:
{ "userId": "50", "roleId": "1" }
CRITICAL
Message:
Time:
2019-04-01T14:44:41.225897+0200
Channel:
core
request:
shop:
session:
ERROR
Message:
exception 'PDOException' with message 'SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '30-mobileLogo' for key 'template\_id\_name'' in /kunden/357897\_66583/projects/sw1/vendor/doctrine/dbal/lib/Doctrine/DBAL/Statement.php:168 Stack trace: #0 /kunden/357897\_66583/projects/sw1/vendor/doctrine/dbal/lib/Doctrine/DBAL/Statement.php(168): PDOStatement-\>execute(NULL) #1 /kunden/357897\_66583/projects/sw1/engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(281): Doctrine\DBAL\Statement-\>execute() #2 /kunden/357897\_66583/projects/sw1/vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(1014): Doctrine\ORM\Persisters\Entity\BasicEntityPersister-\>executeInserts() #3 /kunden/357897\_66583/projects/sw1/vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(378): Doctrine\ORM\UnitOfWork-\>executeInserts(Object(Doctrine\ORM\Mapping\ClassMetadata)) #4 /kunden/357897\_66583/projects/sw1/vendor/doctrine/orm/lib/Doctrine/ORM/EntityManager.php(356): Doctrine\ORM\UnitOfWork-\>commit(NULL) #5 /kunden/357897\_66583/projects/sw1/engine/Shopware/Components/Form/Persister/Theme.php(61): Doctrine\ORM\EntityManager-\>flush() #6 /kunden/357897\_66583/projects/sw1/engine/Shopware/Components/Theme/Configurator.php(133): Shopware\Components\Form\Persister\Theme-\>save(Object(Shopware\Components\Form\Container\TabContainer), Object(Shopware\Models\Shop\Template)) #7 /kunden/357897\_66583/projects/sw1/engine/Shopware/Components/Theme/Installer.php(169): Shopware\Components\Theme\Configurator-\>synchronize(Object(Shopware\Themes\Test\Theme)) #8 /kunden/357897\_66583/projects/sw1/engine/Shopware/Components/Theme/Installer.php(130): Shopware\Components\Theme\Installer-\>synchronizeThemes() #9 /kunden/357897\_66583/projects/sw1/engine/Shopware/Controllers/Backend/Theme.php(203): Shopware\Components\Theme\Installer-\>synchronize() #10 /kunden/357897\_66583/projects/sw1/engine/Library/Enlight/Controller/Action.php(193): Shopware\_Controllers\_Backend\_Theme-\>listAction() #11 /kunden/357897\_66583/projects/sw1/engine/Library/Enlight/Controller/Dispatcher/Default.php(563): Enlight\_Controller\_Action-\>dispatch('listAction') #12 /kunden/357897\_66583/projects/sw1/engine/Library/Enlight/Controller/Front.php(222): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #13 /kunden/357897\_66583/projects/sw1/engine/Shopware/Kernel.php(202): Enlight\_Controller\_Front-\>dispatch() #14 /kunden/357897\_66583/projects/sw1/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #15 /kunden/357897\_66583/projects/sw1/vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true) #16 /kunden/357897\_66583/projects/sw1/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #17 /kunden/357897\_66583/projects/sw1/vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #18 /kunden/357897\_66583/projects/sw1/engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #19 /kunden/357897\_66583/projects/sw1/shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #20 {main} Next exception 'Doctrine\DBAL\DBALException' with message 'An exception occurred while executing 'INSERT INTO s\_core\_templates\_config\_elements (type, name, position, default\_value, selection, field\_label, support\_text, allow\_blank, less\_compatible, attributes, container\_id, template\_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)' with params ["theme-media-selection", "mobileLogo", 0, "s:47:\"frontend\/\_public\/src\/img\/logos\/logo--mobile.png\";", "N;", "\_\_smartphone\_\_", null, 1, 0, "a:1:{s:14:\"lessCompatible\";b:0;}", 157, 30]:
