Call the URL in the same domain with Iframe in Shopware 6
Hi
I am trying to access a page in the same domain using an iframe
I am getting the following error
Refused to display 'http://localhost:8000/' in a frame because it set 'X-Frame-Options' to 'deny'.
is there any way to call the URL in the same domain with Iframe in Shopware 6?
It is a Apache or nginx configuration option, not Shopware.
I have to override this file using service decorator
Shopware\Core\Framework\Routing\CoreSubscriber
and modify
$response->headers->set('X-Frame-Options', 'deny');
This solved my issue.
But how do you modify. Whats the commant for deny
Unfortunately my answer wasn’t correct. Please use @abinjohnedamana answer.
