Call shopware admin controller in backend from custom admin module in frontend
I have created the next admin controller to cancel stripe subscriptions:
File: plugins/ApiKeySubscriptionPlugin/src/Controller/SubscriptionController.php
#[Route(defaults: ['_routeScope' => ['api']])]
class SubscriptionController extends AbstractController
    private EntityRepository $subscriptionRepository;
    //public function __construct(ParameterBagInterface $params, LoggerInterface $logger)
    public function __construct( EntityRepository $subscriptionRepository)
        $this->subscriptionRepository = $subscriptionRepository;
     #[Route(path: '/api/subscription/cancel', name: 'api.subscription.cancel',  methods: ['POST'])]
    public function cancelSubscription(Request $request, Context $context): JsonResponse
        $data = json_decode($request->getContent(), true);
        $subscriptionId = $data['subscriptionId'] ?? null;
        if (!$subscriptionId) {
            return new JsonResponse(['success' => false, 'message' => 'No subscription ID provided'], 400);
        try {
            // Initialize Stripe with the secret key securely from environment or parameter bag
            //$stripeApiKey = $this->params->get('stripe.secret_key'); // Fetch from services.xml or .env
            $stripeApiKey = $_ENV['STRIPE_API_KEY'];
            if (!$stripeApiKey) {
                throw new \Exception('Stripe API key is not set.');
            Stripe::setApiKey($stripeApiKey); // Set your Stripe API key from .env file
            // Retrieve the subscription from Stripe
            $subscription = Subscription::retrieve($subscriptionId);
            if (!$subscription) {
                return new JsonResponse(['error' => 'Subscription not found!!!'], 404);
            // Cancel the subscription immediately
            $canceledSubscription = $subscription->cancel();
            // Update your Shopware entity to reflect the cancellation
            $data = [
                'isActive' => false,
            $this->updateSubscriptionByExternalId($subscriptionId, $data);
            return new JsonResponse(['success' => true, 'subscription' => $canceledSubscription], 200);
        } catch (\Exception $e) {
            // Log the error or handle it accordingly
            return new JsonResponse(['error' => $e->getMessage()], 500);
I wanna call cancelSubscription in the backend from a custom admin module in the frontend.
Therefore I have the next file with my vue component:
plugins/ApiKeySubscriptionPlugin/src/Resources/app/administration/src/module/page/apikey-subscription-list/index.js
And the next functions:
        async onCancelSubscription(item) {
            console.log('Cancel Subscription clicked for:', item);
            // Ensure subscriptionId is properly accessed
            const subscriptionId = item.stripeSubscriptionId;
            if (!subscriptionId) {
                console.error('No subscription ID found in the provided item');
                return;
            // Optional: Show a confirmation dialog
            // Use the native browser confirm dialog for now
            const confirmed = window.confirm(`Are you sure you want to cancel the subscription for "${item.stripeSubscriptionId}"?`);
            if (!confirmed) {
                return;
            this.isLoading = true;
            try {
                const token = await this.getOAuthToken();
                if (!token) {
                    throw new Error('Failed to retrieve OAuth token');
                const response = await fetch('/api/subscription/cancel', {
                    method: 'POST',
                    headers: {
                        'Content-Type': 'application/json',
                        'Authorization': `Bearer ${token}`,
                    body: JSON.stringify({
                        subscriptionId: subscriptionId
                const result = await response.json();  // Get the raw response as json
                console.log('Raw Response Json:', result);
                if (result.success) {
                    console.log('Subscription canceled successfully!!!');
                } else {
                    throw new Error(result.message || 'Unknown error occurred');
                // Refresh the list
                this.getList();
            } catch (error) {
                console.error('Error canceling subscription:', error);
            } finally {
                this.isLoading = false;
        async getOAuthToken() {
            const url = 'http://localhost:8080/api/oauth/token';
            const data = {
                client_id: "SWIAUWP3NFDDAXRYEGNVT0WWWW",
                client_secret: "NXRjUXZBNTU4SEQ4cXNtd2I5VldUSDBCOGJPWndSTVlXampLNWW",
                grant_type: "client_credentials"
            try {
                const response = await fetch(url, {
                    method: 'POST',
                    headers: {
                    body: JSON.stringify(data)
                if (!response.ok) {
                    throw new Error(`Failed to retrieve token: ${response.statusText}`);
                    console.log(`Failed to retrieve token: ${response.statusText}`);
                // console.log('OAuth Token:', result.access_token);
                return result.access_token;
            } catch (error) {
                console.error('Error retrieving OAuth token:', error);
                return null;
How can avoid to expose in the browser my client_secret and client_id ?
