All installation steps are fine but when i try to login into admin section over ssl i get “e.response is undefined something went wrong requesting” but when login without ssl connection it works fine.
Am getting error in browser debug console for vendor.nodejs as it was blocked from loading in browser
problem was with my reverse proxy for jwilder/nginx-proxy had to set the environment VIRTUAL_PROTO: https and VIRTUAL_PORT: 443 this solved it.
Hi ssalipro,
I have exactly the same problem. How exactly did you fix your problem?
Thank you very much for your support and feedback.
Many greetings
Stefan Börner
