Adding one-to-many relationship in admin frontend
Hello, I am trying to create a one-to-many relation between a Customer and a custom entity (Company).
One company can have multiple customers.
I created a new entity in MyPlugin/scr/Core/Content/Company:
name;
     * @param string $name
    public function setName(string $name): void
        $this->name = $name;
     * @return CustomerCollection
    public function getCustomers(): CustomerCollection
        return $this->customers;
     * @param CustomerCollection $customers
    public function setCustomers(CustomerCollection $customers): void
        $this->customers = $customers;
I also created a CompanyCollection.php in the same folder:
I created a CompanyDefinition.php in the same folder:
    protected function defineFields(): FieldCollection
        return new FieldCollection(
                (new IdField('id', 'id'))->addFlags(new PrimaryKey(), new Required()),
                (new StringField('name', 'name'))->addFlags(new Required()),
                new OneToManyAssociationField('customers', CustomerDefinition::class, 'company_id'),
In MyPlugin\MyPlugin\Core\Checkout\Customer I created a CustomerExtension.php:
add(
            (new ManyToOneAssociationField(
                'company',
                'company_id',
                CompanyDefinition::class,
                'id'
    public function getDefinitionClass(): string
        return CustomerDefinition::class;
I created two migrations, the first one MyPlugin/scr/Migration:
executeQuery($query);
    public function updateDestructive(Connection $connection): void
And the customer extension migration:
updateInheritance($connection, 'customer', 'company_id');
This creates the neccesary database tables, and as far as I can tell this works fine.
Now I want to create a relation in the admin panel. I created a new section in the admin panel by creating a file in MyPlugin/src/Resources/admin/src/main.js:
import './page/company-list';
import './page/company-detail';
Shopware.Module.register('my-plugin-company', {
    type: 'plugin',
    title: 'Debtors',
    description: 'Module to configure Companies in Shopware',
    color: '#f12091',
    icon: 'default-building-home',
    routes: {
        list: {
            component: 'company-list',
            path: 'list'
        detail: {
            component: 'company-detail',
            path: 'detail/:id',
            meta: {
                parentPath: 'my.plugin.company.list'
    navigation: [{
        label: 'Companies',
        color: '#f12091',
        path: 'my.plugin.company.list',
        position: -4
I want to have a multisearch box on the company detail page, but nothing I tried seems to work. Here is my index.js for the company detail page:
import template from './company-detail.html.twig';
const {Criteria} = Shopware.Data;
Shopware.Component.register('company-detail', {
    template,
    inject: [
        'repositoryFactory'
    metaInfo() {
        return {
            title: this.$createTitle()
    data() {
        return {
            company: null,
            repository: null,
    created() {
        this.repository = this.repositoryFactory.create('my_plugin_company');
        this.getCompany();
    computed: {
        customerColumns() {
            return [
                    property: 'lastName',
                    label: this.$tc('sw-customer.detailAddresses.columnLastName')
                    property: 'firstName',
                    label: this.$tc('sw-customer.detailAddresses.columnFirstName')
    methods: {
        getCompany() {
            this.repository
                .get(this.$route.params.id, Shopware.Context.api)
                .then((entity) => {
                    this.company = entity;
And my template:
{% block my_plugin_company_detail %}
                    Customers
Now this doesnt work. Extra info i didnt include to prevent making this post any longer:
  • I added my custom definitions in my services.xml
  • I created the /public/administration/js/my-plugin.js file and the corresponding view, and rebuild all assets
Please tell me what I have to do to create a one to many relation in the admin panel. I want to be able to select a customer from the company detail page, and create a relation between the entities. Thanks!
@sznvs did you found a solution for this ?
I am stuck with the problem to create/update associated data from the administration
