Add custom field to global search - not working
hello, I would like to add custom search according to Add custom data to the search | Shopware Documentation
However, I feel like this guide has a lot of mistakes…
I added code like below
const { Application } = Shopware;
Application.addServiceProviderDecorator('searchTypeService', searchTypeService => {
    searchTypeService.upsertType('test', {
        entityName: 'test',
        placeholderSnippet: 'foo-bar.general.placeholderSearchBar',
        listingRoute: 'test',
        hideOnGlobalSearchBar: false,
    return searchTypeService;
but when I try find something I get error „Can not get module by the entity name is test“ why? what I must do more ? Entity test exist and working.
I tried creating a new module… but what I need to type in decorator ?
        entityName: 'test',
My new module:
Shopware.Module.register('test', {
    entity: 'test',
    defaultSearchConfiguration: {
        _searchable: true,
            _searchable: true,
            _score: 500,
        description: {
                _searchable: true,
                _score: 500,
and my decorator
**import '../module/test/index'** // my module import
        entityName: 'test',
        placeholderSnippet: 'test',
{imported module and using}
nothing changes, it same error.
main.js
import './decorator/searchTypeServiceDecorator'
structure
where is the problem ?
Hey there,
See in my opinion: Here are the steps to ensure everything is correctly set up:
  1. main.js
import './decorator/searchTypeServiceDecorator';
import './module/test/index';  // Adjusted the import path based on your structure
  1. Module Registration (in index.js)
    entity: 'test',
        _searchable: true,
            _searchable: true,
            _score: 500,
        description: {
            _searchable: true,
            _score: 500,
  1. Decorator (in searchTypeServiceDecorator.js)
import '../module/test/index'; // Ensure this path is correct
        entityName: 'test',
        placeholderSnippet: 'test.general.placeholderSearchBar',
Make sure to clear the cache after making these changes to ensure they take effect. hope the above will be helpful.
Best,
@wolfsmith
