6.6.4: Scheduled Task run() method will nicht ausführen
Hi liebe Shopware Community,
wir versuchen seit Tagen in der 6.6.4 einen Scheduled Task zum Laufen zu bringen.
Dieser wird auch über systemd alle 15 min richtig scheduled; allerdings wird die run method nie ausgeführt und wir sind kurz vorm Verzweifeln ;( Docs, Videos, alles durch…
Habt ihr eine Idee? Beste Grüße
Task:
custom/plugins/EcomListing/src/Task/EcomListingTask.php
<?php declare(strict_types=1);
namespace EcomListing\Task;
use Shopware\Core\Framework\MessageQueue\ScheduledTask\ScheduledTask;
class EcomListingTask extends ScheduledTask
    public static function getTaskName(): string
        return 'ecom.listing';
    public static function getDefaultInterval(): int
        return 60 * 15; // 15 minutes
    public static function shouldRescheduleOnFailure(): bool
        return true;
Task Handler
custom/plugins/EcomListing/src/Task/EcomListingTaskHandler.php
use Psr\Log\LoggerInterface;
use Shopware\Core\Framework\DataAbstractionLayer\EntityRepository;
use Shopware\Core\Framework\MessageQueue\ScheduledTask\ScheduledTaskHandler;
use Doctrine\DBAL\Connection;
#[AsMessageHandler(handles: EcomListingTask::class)]
class EcomListingTaskHandler extends ScheduledTaskHandler
    public function __construct(
        EntityRepository $scheduledTaskRepository,
        private readonly LoggerInterface $logger,
        private readonly Connection $connection,
        parent::__construct($scheduledTaskRepository, $logger);
        //$this->logger->info(EcomListingTask::getTaskName() . '----------> construct ');
    public function run(): void
        $this->logger->info(EcomListingTask::getTaskName() . '----------> run ');
        $query = $this->connection->createQueryBuilder();
        $query->update('product', 'p')
                     ->set('p.is_closeout', 1);
        try {
            $result = $query->executeQuery();
        } catch (\Doctrine\DBAL\Exception $err) {
            $this->logger->error($err->getMessage());
        $this->logger->info(EcomListingTask::getTaskName() . '----------> finished ');
DI
custom/plugins/EcomListing/src/Resources/config/services.xml
<?xml version="1.0" ?>
<container xmlns="http://symfony.com/schema/dic/services"
           xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
           xsi:schemaLocation="http://symfony.com/schema/dic/services http://symfony.com/schema/dic/services/services-1.0.xsd">
    <services>
        <service id="EcomListing\Task\EcomListingTask">
            <tag name="shopware.scheduled.task"/>
        </service>
        <service id="EcomListing\Task\EcomListingTaskHandler">
            <argument type="service" id="scheduled_task.repository"/>
            <argument type="service" id="logger"/>
            <argument type="service" id="Doctrine\DBAL\Connection"/>
            <tag name="messenger.message_handler"/>
        </service>
    </services>
</container>
Dein EcomListingTaskHandler solte Attribute AsMessageHandler importieren:
use Symfony\Component\Messenger\Attribute\AsMessageHandler;
oh man… danke, danke - das wars!
