Docker installation help
Hi there, I’m looking for help after having following the academy tutorials - I’ve installed shopware using Docker, and part of a project sees that I need to access the shopware webpage from a 2nd VM - on the same network.
The network connection is, both VMs can ping each other etc.
Shopware installed fine, however I can only access the page from localhost:8000
Because I’m new with shopware and Docker, I’m struggling as to how I can give the Docker container either the same address as its host, or a new ip address, either way I need to be able to call the Shopware page from the other VM.
Can anybody help with this?
Thanks in advance.
I have solved this problem over Ubuntu 20.04 redirecting trafic to IP: 127.0.0.1:8000. You can do it by using iptables and these commands:
sysctl -w net.ipv4.conf.all.route_localnet=1
iptables -t nat -I PREROUTING -p tcp --dport 80 -j DNAT --to 127.0.0.1:8000
All requests to the server reaching personal IP are routed to 127.0.0.1:8000. Also, you must edit Storefront domain and include your URL domain or IP.
