Hello. I see on the upgrade page for 5.6.0 that it says:
License manager
The license manager must be uninstalled and deleted before the update.
What does this mean exactly, and would there be a way to automate that if I was going to automatically upgrade a lot of Drupal apps?
Thanks,
Rowan Crawford
Installatron.com
The License Manager ist a Shopware plugin. Just use the Plugin Manager to uninstall.
There is no need to uninstall the Shopware License Manager when updating Drupal. Drupal has nothing to do with Shopware.
Regards
Matt
Oh it’s a plugin! Thanks.
And sorry, I mispoke when I said Drupal, I meant Shopware. Would deleting License Manager be as simple as deleting a directory somewhere, if I wanted to automate the process with a script, or would I also need to modify one of the app’s database tables as well?
Thanks.
Rowan.
As this is an encrypted plugin I have no deeper knowledge. At least there will be a database entry in s_core_plugins that has to be modified/removed.
If your support account includes developer support you might want to contact them for more information.
Regards
Matt
