bei der Überprüfung des Plugins kommt folgende Warnung.
Leider bin ich gerade überfragt. Was gilt es hier zu korrigieren?
Vielen Dank vorab und Grüße,
Frank
Error Output:
No lock file found. Updating dependencies instead of installing from lock file. Use composer update over composer install if you do not have a lock file.
Loading composer repositories with package information
Your requirements could not be resolved to an installable set of packages.
Problem 1
- Root composer.json requires shopware/platform ~6.4.1.0, it is satisfiable by shopware/platform[6.4.1.0-dev] from composer repo (https://repo.packagist.org) but shopware/platform[dev-trunk, 6.4.x-dev (alias of dev-trunk)] from path repo (platform) has higher repository priority. The packages with higher priority do not match your constraint and are therefore not installable. See https://getcomposer.org/repoprio for details and assistance.
Running update with --no-dev does not mean require-dev is ignored, it just means the packages will not be installed. If dev requirements are blocking the update you have to resolve those problems.
