I’m working on a small connector between a shopware 6 test environment and another database which is gathering product data from sw.
Now, I moved the project over to a new computer and from that point on the json result looks totally different and as you can see a lot of data is missing.
Im calling my shopware client to get all products ( $response = $service->request( ‘GET’, ‘product’); )
But all what I get it this:
array (size=5)
'data' =>
array (size=1)
0 =>
array (size=6)
'id' => string '960e95dbb6f6439a9d4339722c7d773e' (length=32)
'type' => string 'product' (length=7)
'attributes' =>
array (size=56)
'links' =>
array (size=1)
'relationships' =>
array (size=20)
'meta' => null
'included' =>
array (size=2)
0 =>
array (size=6)
'id' => string '6c54c4683bf042b7848e51738745d25d' (length=32)
'type' => string 'tax' (length=3)
'attributes' =>
array (size=5)
'links' =>
array (size=1)
'relationships' =>
array (size=1)
'meta' => null
The result is totally different from what I expected or what is documented. I mean, yes, it is an result and f.e. the ID that I get back it ok. I also can filter for specific product and get at least the correct ID back without any error.
If I run the same code on the old machine I get a lot more product information (sadly I cannot paste the result here yet)
I already recreated the integration. Access-ID and Seq.Key looks ok to me. I also get an authorisation error when I use random Id and key. I thought its permission related, thats why.
Can somebody explain this result set? is something missing?
Would be great to get an idea, thx
