Solved: ChildLineItems are set to quantity 0
There is a bug in Shopware 6, where the quantity of ChildLineItems is set to 0 if any discounts are present.
The reason is that for the discount calculation, the items are „attempted“ to be cloned in LineItem::createFromLineItem(). As ChildLineItems are objects, there are not copied but referenced.
The solution is a decorator:
class LineItemQuantitySplitterDecorator extends LineItemQuantitySplitter
public function getDecorated()
    return LineItemQuantitySplitter::class;
public function split(LineItem $item, int $quantity, SalesChannelContext $context): LineItem
    $item = clone($item);
    return parent::split($item, $quantity, $context);
This post is made in the hope that it pops up in the search of another dev - I just spent 12 hours hunting down that bug.
