Da Update wurde manuell hochgeladen und gestartet …
Alle Schritte wurden ohne Fehler durchlaufen, nur abschließen kann ich das Update nicht.
Bei update/done bekomme ich folgenden Fehler …
Slim Application Error
Type: Doctrine\ORM\Mapping\MappingException
Message: No mapping found for field ‚shop‘ on class ‚Shopware\Models\Attribute\Shop‘.
File: /var/www/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/MappingException.php
Line: 163
Trace
#0 /var/www/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataInfo.php(1256): Doctrine\ORM\Mapping\MappingException::mappingNotFound(‚Shopware\Models…‘, ‚shop‘)
#1 /var/www/httpdocs/engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(447): Doctrine\ORM\Mapping\ClassMetadataInfo->getAssociationMapping(‚shop‘)
#2 /var/www/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(2710): Doctrine\ORM\Persisters\Entity\BasicEntityPersister->loadOneToOneEntity(Array, Object(Shopware\Models\Shop\Shop))
#3 /var/www/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/ObjectHydrator.php(271): Doctrine\ORM\UnitOfWork->createEntity(‚Shopware\Models…‘, Array, Array)
#4 /var/www/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/ObjectHydrator.php(492): Doctrine\ORM\Internal\Hydration\ObjectHydrator->getEntity(Array, ‚shop‘)
#5 /var/www/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/ObjectHydrator.php(162): Doctrine\ORM\Internal\Hydration\ObjectHydrator->hydrateRowData(Array, Array)
#6 /var/www/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/AbstractHydrator.php(152): Doctrine\ORM\Internal\Hydration\ObjectHydrator->hydrateAllData()
#7 /var/www/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(976): Doctrine\ORM\Internal\Hydration\AbstractHydrator->hydrateAll(Object(PDOStatement), Object(Doctrine\ORM\Query\ResultSetMapping), Array)
#8 /var/www/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(922): Doctrine\ORM\AbstractQuery->executeIgnoreQueryCache(NULL, NULL)
#9 /var/www/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(765): Doctrine\ORM\AbstractQuery->execute(NULL, NULL)
#10 /var/www/httpdocs/engine/Shopware/Models/Shop/Repository.php(309): Doctrine\ORM\AbstractQuery->getOneOrNullResult()
#11 /var/www/httpdocs/engine/Shopware/Bundle/MediaBundle/MediaService.php(302): Shopware\Models\Shop\Repository->getActiveDefault()
#12 /var/www/httpdocs/engine/Shopware/Bundle/MediaBundle/MediaService.php(74): Shopware\Bundle\MediaBundle\MediaService->createFallbackMediaUrl()
#13 /var/www/httpdocs/engine/Shopware/Bundle/MediaBundle/MediaServiceFactory.php(83): Shopware\Bundle\MediaBundle\MediaService->__construct(Object(League\Flysystem\Filesystem), Object(Shopware\Bundle\MediaBundle\Strategy\Md5Strategy), Object(ShopwareProduction33c1daffe3f3d3914a878ce9e2d58a0884de3c73ProjectContainer), Array)
#14 /var/www/httpdocs/var/cache/production_201911280851/proxies/ShopwareProduction33c1daffe3f3d3914a878ce9e2d58a0884de3c73ProjectContainer.php(4522): Shopware\Bundle\MediaBundle\MediaServiceFactory->factory(‚local‘)
#15 /var/www/httpdocs/vendor/symfony/dependency-injection/Container.php(306): ShopwareProduction33c1daffe3f3d3914a878ce9e2d58a0884de3c73ProjectContainer->getShopwareMedia_MediaServiceService()
#16 /var/www/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(220): Symfony\Component\DependencyInjection\Container->get(‚shopware_media…‘, 1)
#17 /var/www/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(141): Shopware\Components\DependencyInjection\Container->doLoad(‚shopware_media…‘, ‚shopware_media…‘, 1)
#18 /var/www/httpdocs/var/cache/production_201911280851/proxies/ShopwareProduction33c1daffe3f3d3914a878ce9e2d58a0884de3c73ProjectContainer.php(5720): Shopware\Components\DependencyInjection\Container->get(‚shopware_media…‘)
#19 /var/www/httpdocs/vendor/symfony/dependency-injection/Container.php(306): ShopwareProduction33c1daffe3f3d3914a878ce9e2d58a0884de3c73ProjectContainer->getThemeServiceService()
#20 /var/www/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(220): Symfony\Component\DependencyInjection\Container->get(‚theme_service‘, 1)
#21 /var/www/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(141): Shopware\Components\DependencyInjection\Container->doLoad(‚theme_service‘, ‚theme_service‘, 1)
#22 /var/www/httpdocs/var/cache/production_201911280851/proxies/ShopwareProduction33c1daffe3f3d3914a878ce9e2d58a0884de3c73ProjectContainer.php(5712): Shopware\Components\DependencyInjection\Container->get(‚theme_service‘)
#23 /var/www/httpdocs/vendor/symfony/dependency-injection/Container.php(306): ShopwareProduction33c1daffe3f3d3914a878ce9e2d58a0884de3c73ProjectContainer->getThemeInstallerService()
#24 /var/www/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(220): Symfony\Component\DependencyInjection\Container->get(‚theme_installer‘, 1)
#25 /var/www/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(141): Shopware\Components\DependencyInjection\Container->doLoad(‚theme_installer‘, ‚theme_installer‘, 1)
#26 /var/www/httpdocs/recovery/update/src/DependencyInjection/Container.php(189): Shopware\Components\DependencyInjection\Container->get(‚theme_installer‘)
#27 /var/www/httpdocs/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection{closure}(Object(Pimple\Container))
#28 /var/www/httpdocs/recovery/common/src/DependencyInjection/Container.php(71): Pimple\Container->offsetGet(‚shopware.theme_…‘)
#29 /var/www/httpdocs/recovery/update/src/app.php(169): Shopware\Recovery\Common\DependencyInjection\Container->get(‚shopware.theme_…‘)
#30 [internal function]: {closure}()
#31 /var/www/httpdocs/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#32 /var/www/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#33 /var/www/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#34 /var/www/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#35 /var/www/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#36 /var/www/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#37 /var/www/httpdocs/recovery/update/index.php(57): Slim\Slim->run()
#38 {main}
Ich hoffe jemand hat hier eine Idee …
Gruß
Talki
