Hi All,
I’ve set images on the properies for the products. These show perfect in the filter.
Is there also a way to show them on the properies tab on the product detail page?
Thanks,
Tim
Hi All,
Thanks,
Tim
Guess you have to customise the theme/template. In the dev environment you can get all available vars with {{ dump() }}
Theme dev fixed it.
anyway thanks for the response.
Bravo, dev ![]()
I also see the images of the properties in the filter. But as you, i want to show them on product detail page as well.
Can you post how he solved it? Because when using {{ dump() }} then we only get the propertyIDs. Not really the images. Or maybe someone knows the solution?
Thank you very much,
Andreas
