folgendes Problem: Seit dem update auf Shopware 5.4.3, wo ja die Datenschutzbestimmungen DSGVO conform abgehakt werden müssen erhalte ich stündlich eine Fehlermeldung.
Message:
The provided X-CSRF-Token for path "/Onlineshop/EscLegalConnector/" is invalid. Please go back, reload the page and try again.
Time:
2018-05-27T00:52:33.382741+0200
Channel:
core
request:
"uri": "/Onlineshop/EscLegalConnector/",
"method": "POST",
"query": {
"module": "frontend",
"controller": "Onlineshop",
"action": "EscLegalConnector"
"post": {
"xml": "\n\n\t1.0\n\tc1df8838d01b3849cba1b822d0303fe2\n\tdatenschutz\n\tde\n\tDE\n\tgetaccountlist\n"
session:
No session data available
Message:
Shopware\Components\CSRFTokenValidationException: The provided X-CSRF-Token for path "/Onlineshop/EscLegalConnector/" is invalid. Please go back, reload the page and try again. in /home/.sites/74/site2991830/web/Onlineshop/engine/Shopware/Components/CSRFTokenValidator.php:149
Stack trace:
#0 /home/.sites/74/site2991830/web/Onlineshop/engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator->checkFrontendTokenValidation(Object(Enlight_Controller_ActionEventArgs))
#1 /home/.sites/74/site2991830/web/Onlineshop/engine/Library/Enlight/Event/EventManager.php(220): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#2 /home/.sites/74/site2991830/web/Onlineshop/engine/Library/Enlight/Controller/Action.php(176): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#3 /home/.sites/74/site2991830/web/Onlineshop/engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight_Controller_Action->dispatch('indexAction')
#4 /home/.sites/74/site2991830/web/Onlineshop/engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#5 /home/.sites/74/site2991830/web/Onlineshop/engine/Shopware/Kernel.php(215): Enlight_Controller_Front->dispatch()
#6 /home/.sites/74/site2991830/web/Onlineshop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(486): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#7 /home/.sites/74/site2991830/web/Onlineshop/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#8 /home/.sites/74/site2991830/web/Onlineshop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(253): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /home/.sites/74/site2991830/web/Onlineshop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(270): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /home/.sites/74/site2991830/web/Onlineshop/engine/Shopware/Components/HttpCache/AppCache.php(143): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /home/.sites/74/site2991830/web/Onlineshop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(201): Shopware\Components\HttpCache\AppCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /home/.sites/74/site2991830/web/Onlineshop/engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#13 /home/.sites/74/site2991830/web/Onlineshop/shopware.php(118): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#14 {main}
Das merkwürdige, Onlinehop, diesen Ordner gibt es nicht mehr. War nur in der Entwicklungsphase. Shopware liegt nun direkt im Hauptverzeichnis. Wie funktioniert es, das der Pfad Onlineshop entfernt wird. Weiss hier einer ein Lösung?
danke,
Jozi
den Wartungsmodus hatte ich bisher nur wenn ich solange “weggegangen” bin und anschließend nicht auf weiter geklickt habe - das löschen von ./var/cache/production… hat damals geholfen aber eigentlich sollte das ja sauber durchlaufen.
